A little supercharger whine
Old Oct 15, 2007 | 02:02 PM
RAFFIE55's Avatar
Used to drive E55
I have been hearing a little whine from the engine compartment. sort of like a supercharger. Except I don't have supercharger. So any ideas? My best guess is the belt tensioner or pully. Is it something I should worry about or just keep an eye on if it gets worse?
Old Oct 15, 2007 | 02:11 PM
markmam1's Avatar
W203 C230k '05
Oh man bad news your head gasket is worn out leaking oil on the side of you engine and you probably have the oil and coolant mixing together.
just kidding its probably your A/C compressor
Try turning it of and you will here a difference
Old Oct 15, 2007 | 02:33 PM
Nocturnal-G's Avatar
2002 E55 AMG
When I was E55 shopping... I test drove one at the Volvo dealership in Cerritos... it had a "supercharger" whine.. I got excited popped the hood, no supercharger. My E55 doesn't have that sound. Thank God, but yeah... check your belts, sounds like a belt problem to me.. I'm not sure but I would say Alternator belt.
Old Oct 16, 2007 | 02:10 AM
jordanst2's Avatar
1999 e55 (past), 2002 CLK55 (past), 2004 E55 (present), 2008 Z06
The vehicle has a serpentine belt....
Old Oct 16, 2007 | 02:40 AM
2002 E55 AMG
Which basically powers the battery, correct? I'm new to cars... so yeah. Take it easy.
Old Oct 16, 2007 | 10:14 AM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
Could be a few things like the a/c compressor and belt mentioned above or a pulley. Check the belt for wear and cracks. If it still sounds bad we can take it to my buddy's shop in Pasadena if and when you have some time.
Old Oct 17, 2007 | 06:54 PM
MBspdfrk's Avatar
2014 ML 350 Bluetec
I had that too. It turned out to be the alternator was going bad.
Old Oct 17, 2007 | 07:21 PM
topdeez's Avatar
2012 E350 4matic/97 e320 and 01 ml320
I had the same problem, it ended up being a $3800 transmission job.
Heard the same supercharger whine, it was nice for a while until my gears started to slip.
Rock
Old Oct 18, 2007 | 04:31 AM
migs's Avatar
carefull if it's the belt... if it snaps you will overheat since it also drives the waterpump
