Suspension question
By the way, what size spring pads are you sitting on? If you left the stock #3 pads in there, that is why you're probably not happy with the drop. Make sure that you have or if you don't, install #1 pads in there all around and with the H&R sports, you should be happy with the drop. I was happy with mine back on my E420 and Raffi has the H&R sports on his 55 and the drop is nice on his stock 18" Monos.
, so if you guys stop seeing my posts , look for me somewhere with a spring attached to me !
If and once they settle it's still too high for you, swap out the H&R's for some Eibach Pros, I love these springs.
If you have a spring compressor and somewhat mechanically inclined the job is fairly easy. You only need the compressor for the front and as long as it's on there nice and snug, no worries. In the rear, if you just remove the bolt on the arm holding the shock with a jack underneath it, you can lower the shocks and pull the springs out very easily and safely.
Good luck man!
