Fog lights on 2001 E55
Old Jan 21, 2002 | 12:56 AM
Edmond W.'s Avatar
2001 AMG E55
Has anyone changed or should I say, does anyone know how to change the fog light bulbs on a 2001 E55???
I wanted to change the current bulbs to HID bulbs but don't know how to. I tried to tinker wtih it but can't seem to figure it out. Also, what bulbs do I need (part #?). Can I change the bulb only or do I have to change the entire fog light??
Any help or direction would be greatly appreciated.
Regards,
Edmond
Old Jan 25, 2002 | 02:10 AM
Edmond W.'s Avatar
2001 AMG E55
Does anyone know??
Old Jan 25, 2002 | 10:23 AM
JamE55's Avatar
Out Of Control!
Edmond
You may also want to try posting this on the Tech forum and MBTech might be able to help you.
Old Jan 30, 2002 | 01:38 AM
Edmond W.'s Avatar
2001 AMG E55
Thanks JamE55
Old Jan 31, 2002 | 02:08 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Edmond W.
You can not take out a halogen bulb and replace it with a "real" Xenon HID bulb. Unless you are referring to using "fake" blue Xenon look-a-like halogen bulbs. An HID bulb and a halogen bulb are not interchangeable.
Your foglight bulb is probably a halogen H1 bulb. In order to make your fog lights HID you would need to convert or retrofit it with an H1 HID conversion kit. Changing the fog light to HID is probably not recommend because the foglight wiring, housing, optics and lenses are not good enough to handle the conversion and improve the lighting.
