Going into the shop this week, anything else I should look for?
I'll be lowering my car this week (H&R Sports + Bilstein Sports), so I decided to replace the sway bar links and maybe control arm bushings while it's there. The guy said the links typically run $150 installed. Does that sound reasonable?
I have a slight clank/knock coming from my driverside front when I hit bumps with window open only (not that loud).
I asked him to give me the GRAND total for; Shocks & Springs install, alignment, sway bar links, and possibly control arm bushings if needed.
Just waiting for a call back. It's a repituble shop, so I know they'll do a great job.
Let me know if theres anything else I should have them look at, while they're working on the suspension anyway?
I want a nice tight ride.
Thank you in advance!
Leerod you should be buying your parts here
http://www.autohausaz.com/search/car...0%20320%203789
Indy shops are good for labor save your money and show up w/the Parts in your backseat
Ordered my sway bar links last night. $44 2-day shipping! Not bad!
SWAY BAR LINKS
Thanks again, Johnny!
SWAY BAR LINKS
JEAH!
I found a good spot through a friend, that'll do the whole install for $230 give or take. Including the sway bar links I ordered.
New question: Someone mentioned that I may need new sway bar bushings? I'm not sure if I even understood him correctly. Any idea?
SWAY BAR LINKS
SWAY BAR LINKS
