200 E55/difficult starting
On a regular basis, after a fill up and a secure tightening of the gas cap, the car is very hard to start. And, sometines with the car in park and with the engine running, the engine quits.
This happens in normal temperatures and is happening a bit more frequently than before
Is this a tank pressure problem or a fuel pump problem?
I would appreciate any ideas and thoughts.
Tonight on the way home, the engine stopped in heavy stop and go traffic with no warning lights prior to stopping. After 15 minutes I was finally able to get it re started...again no warning lights.
Is there anything else I should look for before it goes into MB for another round of problem solving?
Thanks for the counsel on this It is going into my local MD dealer for the Service A and to get this engine stopping problem addressed. I will write up the suggestions I have had from youall and give that to them so they can go to the recommended solutions first. I am quite thankfull I bought the extended warranty when I bought the car from the original owner!!
I will let you know what the solution is for this. I love this ride and plan on keeping it. But, it is my business car and I have to have it 100% reliable.
My best
The part was 137.00 plus labor. Around here, Chicago metro, labor at the MB dealers is around 100.00 per hour. Fortunately I have the extended warranty so it was covered on this. Again, thanks for the guidance.
You'r welcome bud!!
Thanks to you for post! great to see solved your problem! Fabio Daniel
takes you all of 15 minutes to replace and properly index to the system.
DIY is on w210 section of www.benzworld.org and diy resource section of www.peachparts.com
Might save someone not on warranty some big bucks someday if he runs across this very typical problem(hot stalls,cool restarts)
66k miles it is past time to change your trans fluid and filter. MB spec 722.6 fluid only please
tuning tools, spare parts,tech support,722.6 dipsticks,17mm boot plug tool
