power and mods
Old Jul 16, 2009 | 05:35 PM
luiscalpa's Avatar
2000 E55
Originally Posted by Fabio D
+++++++++, the primarys are an extreme restriction in the final of the exhaust manifold same as said AMS. i can said how i feel in my car (primary & secondary delats with only 2 O2's) i fell a little lose low end torque (1000 - 2000 rpm's range), but really a minimal "take in accont in a 350 hp's + 1 or 2 hp's is imposible feeling) but really about 3000rpm+ the difference are drastical in a hi end torque! im not have dyno charts for this mod, but work!
If you go to remove yours (purchase the right exhaust union sealant "befor the secondary cat" mid the union with 2 screws.. always broken when you uninstall the exhaust system)
Hope that help
Fabio Daniel
hi Im thinking this saturday to put the x pipe and remove the primary cats, wright now I dont have the secondary cats, and I have stock intake filters. My question is does it will sound to loud?
thanks
luis..........
Old Jul 16, 2009 | 06:50 PM
AMS Performance's Avatar
Former Vendor of MBWorld
AMG
Hey Luis,
I would not eliminate primaries, it will be too raspy and you will get CEL if it is a USA spec car. Upgrade your air filters to K&N filters. Keep the primaries and just put in the X-pipe. The X-pipe will definitely help give you more power on the top end and improve sound significantly without too much resonance. hope that helps
~AMS~
Old Jul 16, 2009 | 09:25 PM
Fabio D's Avatar
210 55
thanks
luis..........
I agree with AMS luis. if your car is an US spec you will have a CEL if you remove the primarys, anyway, my car is an euro without primarie & secons, deleated with direct pipe & the sound of the car realy are very close to the stock (i conserve the center & final resonator for now)
Hope that help
Fabio Daniel
Old Jul 16, 2009 | 10:06 PM
luiscalpa's Avatar
2000 E55
thanks guys!!!
Old Jul 17, 2009 | 12:13 AM
pinoyk20's Avatar
99 model w210 e55 amg
i guess the best combo mods would be the ams package with header,pulleys, ecu tune and xpipe alos primary and secondary hi flow cats! and the good thing is thta its bolt on power! AMS FTW!!!
Old Jul 17, 2009 | 12:49 AM
armaniE55's Avatar
2012 CLS63 AMG
Thumbs up
+1 Can't get any easier than that
Armani
Old Jul 17, 2009 | 04:10 AM
  #32
Silver Logic's Avatar
W210 E55 AMG
Hope that help
Fabio Daniel
True. My friend has a euro car and has deleted all his cats, and kept his headers, resonator, and muffler stock. You can hardly tell any sound difference from stock.
Old Jul 17, 2009 | 08:47 AM
  #33
pinoyk20's Avatar
is that the e60 sir? heheeh when will you be orderin the pulleys sir silver logic? thakns
Old Jul 18, 2009 | 03:13 AM
  #34
W210 E55 AMG
No, E50 and E55. The E60, has all his cats and resonator removed. Initially, he was basically running a straight pipe from the factory headers all the way to his stock muffler. When he realized he lost some torque, he put in a X-pipe. On idle, the E60 sounds normal, but when he his revs get higher, it sounds loud.
Old Jul 20, 2009 | 09:55 PM
  #35
Fabio D's Avatar
210 55
Thats correct my friend!, if your car is an Euro spec you can remove all 4 cats & conserve the stock sound (a bit louder, but really a little little bit)
Fabio Daniel
Old Jul 20, 2009 | 11:13 PM
  #36
AMG
Removing all 4 cats will let more resonance through but realistically cats make the biggest difference once the cam opens up @ around 3500+, below that it won't make a huge difference in sound. With that said, the car fumes will stink pretty bad and also its terrible for the environment.
On a euro car since you don't have primaries, running high flow 300-cell metal core cats will be comparable running high flow primaries & no secondaries on a US spec car. Just get a set of high flow metal core cats, they are only 180 and there's only 1-2HP difference between that and straight pipes, so might as well eliminate the fumes & preserve the environment for that little of a gain.
Old Jul 20, 2009 | 11:45 PM
  #37
armaniE55's Avatar
2012 CLS63 AMG
Thumbs up
Originally Posted by suicidal4life
AMS is right. You really only feel the increase in the upper RPM's.
Awaiting install•Stiegemeier ported HPS gen1 SC•SLR cams•Coolingmist•Wald EX bodykit•VRP intake spacers•Eisenmann race•Quaife LSD
Old Jul 21, 2009 | 09:49 AM
  #38
nicobaires's Avatar
13' E550, 14' Ram, 99' E39 wagon
Thumbs up
Oh yeah!!
Old Jul 21, 2009 | 10:50 AM
  #39
pinoyk20's Avatar
thats what i call super mods!!!!
Old Jul 23, 2009 | 04:28 PM
  #40
Simon @ evosport's Avatar
PREMIER SPONSOR
Here is a Product Guide to our mods for M113 5.5L (non Kompressor):
http://www.evosport.com/product/vehi...Z_V8_55AMG.pdf
Old Jul 24, 2009 | 12:23 AM
  #41
pinoyk20's Avatar
cant open the file.....
Old Jul 24, 2009 | 12:31 AM
  #42
armaniE55's Avatar
2012 CLS63 AMG
You need Adobe PDF reader
try this...
http://get.adobe.com/reader/
Armani
Old Jul 24, 2009 | 03:25 AM
  #43
W210 E55 AMG
I'm curious, that if one does all these modifications will the reliability and longevity of the engine decrease?
Old Jul 24, 2009 | 11:22 AM
  #44
pinoyk20's Avatar
CAN ANYONE PLS POST whats on the link really cant se it hehehehe
Old Jul 24, 2009 | 12:06 PM
  #45
PREMIER SPONSOR
The link works fine. The site just automatically truncates the URL that you see. Make sure you have Adobe Reader downloaded since it's a PDF file. You can also go to our main Product Guide page to select the specific model here:
http://www.evosport.com/product/vehicle/guides
But here's the full link non-truncated to the W210 E55 guide:
www.evosport.com/product/vehicle/guides/MBZ_V8_55AMG.pdf
Old Jul 27, 2009 | 04:04 PM
  #46
Eurosport's Avatar
monowiper
nm
Old Jul 28, 2009 | 12:12 PM
  #47
pinoyk20's Avatar
when you change the headers, x pipe, exhaust diameter and remove the resaonator and cat converters will it have an effect in the fueling of the car? will the engine lean out or not? can the stock AMG ecu cope up/adjust or match with the mods or do you need a ecu tuning? thanks!
and also another question when you change this parts do you have to reset the ecu? thanks!
Old Jul 28, 2009 | 12:31 PM
  #48
PREMIER SPONSOR
It will have an effect on backpressure (so be careful what you change or you could easily lose torque), and yes it could very well make the car run lean depending on what exactly you change pre O2 sensors. The stock ECU can do some adaptation but again it depends on what the A/F look like with the mods. An ECU mod can certainly help add timing and fuel.
No, the ECU will adapt as much as it can using O2/knock sensors.
Old Jul 28, 2009 | 01:23 PM
  #49
pinoyk20's Avatar
oh ok even if i have a euro spec e55 that has 2 o2 sensors only unlike the US models that has 4? will increasing the pipe size from 2.25 to 2.5 increae power and tq or will it have a bad effect? thanks! im planin on putting header, reomve primary and secondary cats install a custom resonator and xpipe and retain the stock muffler... the resonator size will be same as the piping size 2.5inch. will it still make the car run lean? or is it ok with the stock ecu?
Old Jul 28, 2009 | 01:41 PM
  #50
PREMIER SPONSOR
The US cars have 2 rear O2 sensors which are sort of backups. The pre sensors are what trigger the knock sensing. If you have 4 cats, remove the rears, remove the resonators, use a shorty header, keep the primary cats. Really no need to enlarge the diameter of tubing unless you are pushing that MUCH more air into the system. But it's hard to tell what will happen until you try.
