power and mods
Old Jul 12, 2009 | 11:46 AM
pinoyk20's Avatar
99 model w210 e55 amg
power and mods
hi guys! i just want to compile all posible bolt on mods for the w210 e55 amg pls help and this will be very helpfull for all e55 owners planing to modify their cars letsall put down the list of possible power making parts
INTAKE:
RENNTECH
GROUPPE M
AIR FILTER:
BMC
MANN
KNN
PLUGWIRES:
MAGNECOR
PULLEYS
Evosport underdrive pulleys does this really work?
AMS PULLEY
HEADERS:
KLEEMANN
AMS
XPIPE
PIPINGS 2.5 INCH
HI FLOW PRIMARY CATS
HI FLOW SECONDARY CATS
OR WITHOUT PRIMARY AND SECONDARY CATS
ECU:
KLEEMANN
AMS
RENNTECH
THROTTLE BOOSTER
AMG SPRINTBOOSTER
NON AMG SPRINT BOOSTER
please add up all other parts that are bolt on on the e55 that can add power except forced industion like turbo and supercharger. only bolt ons for naturally aspirated engine. thanks
and also has anyone dynoed their e55 w210 via dynojet? what is th stock wheel horsepower and wheel torque? thanks!
and also with all the bolt on parts listed has been done how much horsepower can we expect to gain? thanks
Old Jul 12, 2009 | 02:53 PM
AMS Performance's Avatar
Former Vendor of MBWorld
AMG
That's a pretty comprehensive list, although many of those are not really necessary or cost effective. A good example is intakes, most of them are total waste of money for only a few HP gain. You are better off just doing K&N drop in panel filters for $80 and not doing anything else to the intake system, AMG did an amazing job with the stock airbox, its both cold & ram air. Its not where the real bottle neck is on our cars.
Also, plug wires are honestly overrated and do not really do anything for power. They do look fancy but the OEM wires are more than capable of doing the job. Some claim they are "smoother" than stock but again that's comparing old worn stock wires vs. brand new aftermarket ones. If you were to compare then new vs. new the difference would not be noticed at all (unless it was purely psychological) . In addition, installing & removing them can be a total nightmare compared to stock ones as they are a tight fit.
Removing both primaries & secondary cats are a big no-no, don't even think about it, that's not an option. I wouldn't touch primaries either, Just do the high flow secondaries.
hope that helps.
~AMS~
Old Jul 12, 2009 | 05:58 PM
suicidal4life's Avatar
2001 E430
Old Jul 12, 2009 | 09:12 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Don't forget a supercharger...............they do bolt on.
Old Jul 12, 2009 | 09:28 PM
2001 E430
OP specifically stated no forced induction.
Old Jul 12, 2009 | 09:55 PM
I know, I was talking to you, hope to see that sc bolted on soon.
Old Jul 13, 2009 | 09:18 AM
pinoyk20's Avatar
i added the evosport pulleys. does it work? can you feel the difference with it? thanks!
Old Jul 13, 2009 | 09:20 AM
pinoyk20's Avatar
hope that helps.
~AMS~
why is it a big no no to remove the cats? specially for jdm and eudm spec cars were we only have 2 o2 sensors.not like usdm model with 4 sensors?thanks
Old Jul 13, 2009 | 10:37 AM
NitrogenBalance's Avatar
none
Ha! nice. I was just busting his ***** about the same thing.
Old Jul 13, 2009 | 06:40 PM
2001 E430
I suck!!!
Old Jul 13, 2009 | 06:42 PM
2001 E430
Not a big difference as some people have mentioned but I picked em up for $250 and about an hour and a half of my time to install them so I'll take any little bit I can gain.
Old Jul 13, 2009 | 08:35 PM
AMG
Its not worth the terrible smell and raspiness. If you only have 2 sets of cats anyways then just replace them with high flow 300-cell metal core cats, that will significantly improve performance without any drawbacks.
Old Jul 13, 2009 | 08:37 PM
AMG
Correct, they do make power but really only at higher rpms (usually 5000rpm+ is where most of the gains are). However, in conjunction with our crank pulley they make good numbers and do maximize HP out of the entire pulley system for those looking to squeeze out every last HP.
Old Jul 14, 2009 | 02:00 AM
2001 E430
AMS is right. You really only feel the increase in the upper RPM's.
Old Jul 14, 2009 | 02:18 AM
Silver Logic's Avatar
W210 E55 AMG
I seem a bit confused. If you have secondary cats, you suggest replacing them with 2nd high flow cats while maintaining original primaries. So, if you only have primary cats, why is it necessary to replace them with high flow 300-cell cats?
Old Jul 14, 2009 | 11:40 AM
pinoyk20's Avatar
i can leave with the smell and emisions sice itsnto an issue n our country cause we dont have that much restrictions on sound and emision on vehicles... what would b the pros and cons of removing both primary nd secondary thanks!
Old Jul 14, 2009 | 09:38 PM
Fabio D's Avatar
210 55
Any... in your country no worry.. but you are not GREEN with the earth is the only one & you get a little metal sound after the exhast manifold when you put a direct pipe in this site, but no worry at all
Fabio Daniel
Old Jul 14, 2009 | 09:55 PM
pinoyk20's Avatar
Fabio Daniel
but how about the power.. will it gain or lose power? thanks!
Old Jul 14, 2009 | 10:24 PM
Fabio D's Avatar
210 55
+++++++++, the primarys are an extreme restriction in the final of the exhaust manifold same as said AMS. i can said how i feel in my car (primary & secondary delats with only 2 O2's) i fell a little lose low end torque (1000 - 2000 rpm's range), but really a minimal "take in accont in a 350 hp's + 1 or 2 hp's is imposible feeling) but really about 3000rpm+ the difference are drastical in a hi end torque! im not have dyno charts for this mod, but work!
If you go to remove yours (purchase the right exhaust union sealant "befor the secondary cat" mid the union with 2 screws.. always broken when you uninstall the exhaust system)
Hope that help
Fabio Daniel
Old Jul 15, 2009 | 03:52 AM
pinoyk20's Avatar
thanks so i will be able to gainalot from deleting it.. thats good. how about in headers which would you prefer ams or kleemann? thanks! im aiming for mid to highend power
Old Jul 15, 2009 | 12:00 PM
AMG
There is almost no difference between the two if you upgrade your secondary cats with the shorties, you get the same top end. It is the upgrading/removal of one set of cats that gives you that extra top end not so much the headers themselves. The shorties just do it without sacrificing any bottom end.
Old Jul 16, 2009 | 12:51 PM
pinoyk20's Avatar
so does this mean that the extra lenght of pipe from the long tube headers does not have a different effect on power if compared wit the hort type headers? thanks
Old Jul 16, 2009 | 12:52 PM
pinoyk20's Avatar
it means th kleeman and ams headers produce the same amount of power from lowed,mid and highend power? thanks
Old Jul 16, 2009 | 12:58 PM
AMG
They do slightly as far as where the power comes, but overall "meat under the curve" is very close to each other. Remember, "Long tube" headers which on MB cars aren't even really long tubes (just by name) get much of their power because they delete the primary cats. That's there a huge % of the power comes from. In addition, removing the restricting of the stock primary diameter (going from 1.4" to a larger size) is where majority of the remaining power to be had comes from. The length of the tubing only make a small difference in power in that it shifts power from the lower end of the power band and pushes it up to the higher rpms, but the area under the curve (once you isolate all other factors) hasn't really changed much at all.
Old Jul 16, 2009 | 02:03 PM
pinoyk20's Avatar
cool thanks for the info. btw i have a PM for you . thanks!
