A nice little clip of my AMS/SLP custom exhaust
Old Jul 16, 2009 | 10:02 PM
e55 addict's Avatar
check sig ;)
http://www.youtube.com/watch?v=hkpis7VtUDw
Old Jul 16, 2009 | 10:26 PM
KL2DC's Avatar
W210 E55, W211 E3504M, E90 325i
Sounds beastly! Details?
Old Jul 16, 2009 | 10:40 PM
e55 addict's Avatar
check sig ;)
AMS Shorties, Stock primary cats to a custom ss y-pipe to Single SS 3" straight back to a 3in 3out SLP Baffled Loudmouth with a 3" slash cut tip
Old Jul 16, 2009 | 10:59 PM
KL2DC's Avatar
damn subtle it ain't...
Old Jul 17, 2009 | 12:01 AM
pinoyk20's Avatar
99 model w210 e55 amg
wow i love the sounds! sounds scary! monster V8!
Old Jul 17, 2009 | 12:57 AM
armaniE55's Avatar
2012 CLS63 AMG
Cool
Had to play it twice..... Very Nice
sounds like "move get out the way"
Good stuff
Johnny
Old Jul 17, 2009 | 02:56 AM
AMS Performance's Avatar
Former Vendor of MBWorld
AMG
Holy Crap... that is a "tad" bit loud haha. You should get some driveby clips during the daytime as well
I definitely sounds amazing though. Our headers do have a very unique sound to them because of their design, and you get to hear it more with your specific setup since its basically open headers . You could always just replace the rear muffler with a 14" 5x8 magnaflow (link below, you can bargain with them too) to smoothen the sound a bit while reducing the drone significantly down the road if you want to, but either way, sounds great!
http://cgi.ebay.com/ebaymotors/MAGNA...Q5fAccessories
Old Jul 17, 2009 | 08:09 AM
e55 addict's Avatar
check sig ;)
I wouldnt change a thing.....I am a fan of the open exhaust sound.....you cant match the off throttle sound either.....when I down shift to a stop it sounds like the Superjake in my Peterbuilt
Old Jul 17, 2009 | 04:06 PM
Esh's Avatar
Esh
E55
Move the video camera away from directly behind the exhaust pipe. Perhaps try off to the side a bit and further back.
The mic on the camera makes it distort the sound.
Old Jul 17, 2009 | 04:15 PM
AMG
I agree, putting the camera at a 45 degree angle or from the side of the exhaust tips will prevent mic from picking up distortion & wind noise from exhaust gasses. Also a video of a driveby of the car under full throttle load would be nice too to get a better idea of what it sounds like.
Old Jul 17, 2009 | 04:24 PM
LeeRod80's Avatar
99 E55 AMG
+1!!
Sounds like a beast!!!
Old Jul 17, 2009 | 10:32 PM
RAMON55's Avatar
2002 E55
that thing sounds mean
Old Jul 18, 2009 | 01:03 PM
e55 addict's Avatar
check sig ;)
pulled the cel codes......
well I pulled the codes today........seems my o2's are good as well as my MAF.......the codes were for fuel trim on the right and left bank......PO170 and PO173.....my friend told me (BMW, Porsche tech)my setup may have put my ECU outside it stock parameters but he is not sure on a MB.....He said I may need a tune to compensate.....or is it something else?
Old Jul 18, 2009 | 01:49 PM
saintz's Avatar
GL450
Have you changed your fuel filter recently? I think that's the big part that can get clogged and make you lean out (based on the code, I'm assuming that's the problem).
Old Jul 18, 2009 | 03:10 PM
AMG
If your O2 sensors have not been replaced it will cause your air fuels to be out of spec. Again, O2 sensor codes will only go off if they completely die or are close too it but it takes a long time for that to happen. They still be well out of spec thereby causing your fuel ratios to be off.
If your upstream O2 sensors (before primaries) have never been replaced and you have no maintenance records of having been replaced... then its time to do some maintenance. The same is true of MAFs as well, over time they too go out of spec and replacing that can make a big difference also.
ECU upgrade can help but it won't guarantee to fix the problem because if your stock sensors are out of spec, no amount of tune will cure the problem; it will only be a temporary band aid.
Old Jul 18, 2009 | 03:18 PM
jturkel's Avatar
02 C32 AMG
sounds like one bada$$ ****
