Thoughts on '02 E55 with 146k miles?
miles. Can get it for around $8k. The previous owner knew my mechanic who worked on the car. It's been in a front ender and was repaired with no frame damage. Let me know what you guys think.......Thanks
Brakes cost $1k or more. That's a big one.
I would get an estimate from your mechanic (or a disinterested third party mechanic) for the AC repair and brake job. I would also say the car is worth $8k with the issues fixed (maybe a little less if it has an accident CarFax), so ask him to either fix for that price or negotiate down based on the inspection/estimate from the mechanic.
Edmunds says it's worth about $10k fixed, $8k as is. So, maybe not a bad deal. But make sure what you save up front you put in the bank so you can pay for some repairs down the road.
I thought it only had around 100k miles. Oh well, we'll see what happens.
There is a C36 on this forum for $5K...I'd think about that. He's close to you too.
It is much better to go this route then to do the tranny solenoids which can cause premature wear. You can improve the speed the tranny shifts simply by doing a conventional performance rebuild. Also, you can alter the torque converter if you want (although honestly it isn't recommended on our cars, the stock one is fine you can just make it stronger).
hope that helps.
What? what in the hell did you spend 20k on ?
