E55 FRONT GRILL
Old Oct 15, 2009 | 02:27 PM
pinoyk20's Avatar
99 model w210 e55 amg
E55 FRONT GRILL
hi guys have you noticed the front grill on our car. when i checkd it i discovered that there was a certain are of the grill which is blocking the air to go directly to the intake tubes.. any one have thought of cutting the plastic area so the air can directly go into the intake tubes making it a more RAM AIR effect? thanks
Old Oct 15, 2009 | 03:46 PM
KL2DC's Avatar
W210 E55, W211 E3504M, E90 325i
Hmmmm never noticed, but it might be there for a reason - perhaps to minimize rain water from going directly into the intake?
Old Oct 15, 2009 | 05:39 PM
AMS Performance's Avatar
Former Vendor of MBWorld
AMG
Yes, You can cut off the 4" tab thats blocking it for more airflow. It may help alittle bit but its not going to give you anything measured on a dyno anything. Its more for blocking sound than anything else.
Old Oct 15, 2009 | 11:29 PM
pinoyk20's Avatar
but as KL2DC said wouldnt it let water come in when raining? im sure it will make some gain when the car is running
Old Oct 16, 2009 | 12:46 AM
AMG
No, the technical term for them is "water ingestion baffle". Its for in case you are stupid enough to drive through heavy water. The airbox is so high and its so far offset to the sides that rain will never get in there, you can cut them if you please, many do.
Old Oct 16, 2009 | 02:04 PM
pinoyk20's Avatar
cool so even if i drive on a rainy day the rain water that goes on the front of my car to the grill wont go in the intake? i mean not submerge but you know what i mean like driving 60-100mph on highay on a rainy day will water get in?
Old Oct 16, 2009 | 04:29 PM
AMG
No, not even close. The stock intake is designed so that the air goes upward so its impossible for water to defy gravity, go up, and then into the airbox. Feel free to go ahead and do it.
Old Oct 17, 2009 | 03:10 PM
Esh's Avatar
Esh
E55
My question is why would you be driving 100 mph in the rain?
Old Oct 18, 2009 | 11:34 AM
pinoyk20's Avatar
i used it only as an example so we can tell if its safe to do. and also why did they make the intake to be like that? is there a reason for the cover on the paseenger side intake? did they do it to balance the flow of air on the two intake pipes? because the driverside intake is morerestricted and has small opening?
AMS: yup but if the throttle is open and sucking air their could be a chance for waterto be suck into the motor? thanks
Old Oct 18, 2009 | 02:19 PM
AMG
No, If you are in 4 feet of water, the intake is your least but of concern lol.
Old Oct 18, 2009 | 09:37 PM
sinister99's Avatar
Mercedes E55 AMG
Well in all reality if you put water on a ramp and have air rushing up it. It's going to push the water up the ramp. So same with the intake tubes if you were to have water enter them and driving with a 40mph-however fast you drive air rushing into them.
If you were scared to do it you could always drill holes thru the plastic rather then cut it all the way out. I've see also where some will wrap the end of the intake tubes with screen from a window like on turbos so that water could not directly feed into the tubes. But anyways I guess it's all up to the person.
