rear wheel bearing boys tomorrow
Old Nov 11, 2009 | 10:18 PM
mandrewlt250r's Avatar
300sd 300td e55
I'm taking the hub out. My buddy is gunna press it for me. any tips or suggestions?? I'm pretty mechanistically inclined and i have done them on 1 or 2 other cars. if you guys want when i'll take pics as i'm doing it and post a lil how to the best that i can. give me some feed back and let me know. keep in mind its a $102 part for me and the dealer wants over $800 to do it. LET ME KNOW!!!! I appreciate it.
Old Nov 12, 2009 | 07:48 AM
maxwerks's Avatar
06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
Just make sure to use the right press so as to not marr the inside of the hub when you press the bearings out.. it is pretty tight in there.. I was told the use the grease from Mercedes .. it is Green in color and not too expensive... call first to make sure they have it .. they dont have it stocked regularly for sale. While youre dealing with the wheel bearings check all of your front suspension, ball joints, Tie rod ends, bushings....
Best of luck keep us posted.
Max
Old Nov 12, 2009 | 10:00 PM
Fabio D's Avatar
210 55
Right there! all Ok
You can use the blue lithium Mobil or Mobil RED performance (superior than blue lithium), is very efficient too (i think superior than factory MB green) anyway the green Mercedes is exelent too & you can sayd you use only MB OEM parts
Fabio Daniel
Old Nov 16, 2009 | 09:50 PM
hcetzneb's Avatar
2004 Ran SRT-10,2007 S550,2016 E400c
I think the op is talking about REAR wheel bearing.. the sealed straight rollor type. They do not get packed with grease. They get pressed in and out.
Old Nov 16, 2009 | 09:52 PM
hcetzneb's Avatar
All you need is alittle oil or silicone to help them when pressing
Old Nov 17, 2009 | 02:12 AM
300sd 300td e55
There was no grease involved. It was actually pretty easy. All you have to do is disco all the linkages and the caliper. The hardest part is disco the e brake. Pop the whole thing off press the hub and bearing out the press it in then install in reverse order. BTW I changed ball joints and tie rod ends the week before and it eas Cake. This was a rear bearing.
Old Nov 17, 2009 | 03:22 PM
Lawrence1's Avatar
2011 G55 + others
you must of known how that ebrake bulls*** system goes in and out as it was a PITA when i had to remove mine.
the worst ebrake system design i've ever seen.
good to hear the job went well.
Old Nov 18, 2009 | 07:53 PM
Fabio D's Avatar
210 55
hahahaahaha right yeah if its the rear bearings no need grease, & yes too is a very complicated E brake system, but really works a lot better than other models
Fabio Daniel
