I think Im on to something here. Running with no o2 sensors Tunning potential
Ok guys after messing around with my car for a year https://mbworld.org/forums/w210-amg/...what-heck.html, trying to fight the cars ECU which kept on subtracting fuel and reducing hp output as this a common problem with our cars as i have discovered, After new plugs, plug wires, 4 different maf sensors, new 02 sensors, 100 of ecu resets I have discovered this;
Our cars run great with o2 sensors completely disconnected, as a matter of fact car runs stronger than ever and does not show any signs of ecu adaptation and reducing hp output. Car runs in the open loop which completely disables the ecu adaptation.
So this just hit me today; with even a simple AFC air fuel controller, such as SAFC by Apexi which only manipulates MAF outputs to add or subtract fuel and adjust Air Fuel curve I can add more hp and have control over Air Fuel curve which is very hard to do with most vehicles where ECU keeps on fighting back and readjusting things again. This means I can adjust all driving conditions to a perfect AF curve and ECU wont even blink and with more advance piggy back systems I can adjust Timing and lots more parameters. This will be completely custom tune and will gain the most HP that no basic ECU flash can come close to. And there is more: !!! Since we are not using the o2 sensors anymore we can install a wideband o2 in the place of our stock sensor and this way we car readjust AF curve as necessary with more mods and since we will have the piggy back installed slight adjustments can be made without having to take the car on the dyno
Im exited to try and tune this beast...
Is not th way to gain power bro. completly open loop is good for power. but is not good for the lubrication in the cylinder wall. the fuel exess remove the oil film in the cylinder wall increasing the friction by the ring & the wall.. anyway.. this tip is good to solve some faulty problem same as your thanks in advance
Fabio Daniel
Fabio Daniel
W210 01 E55
Fabio Daniel
Fabio Daniel
U can made a simple prove, put in ur finger a little point of oil & put upside a little touch of gasoline.. this can take you an idea about what made the excess fuel in the cilinder wall.
Fabio Daniel
