E55 Rims
Search terms "W210 AMG wheel specs"
brings you here,
https://mbworld.org/forums/e-class-w...55-wheels.html
There, now you have the W210 AMG wheel specs.
Now search "SL500 wheel specs"
and you can come up with this
https://mbworld.org/forums/wheels-ti...tment-clk.html
You can then run a search in google:
"wheel offset calculator"
and it will bring you here:
http://www.1010tires.com/WheelOffsetCalculator.asp
where you can input the specs and give you this for the front:
and for the rear:
It may not exactly tell you whether or not they will fit, but will give you a lot more information in helping others answer your question if that exact question hasn't been answered before.
brings you here,
Front: ... New Wheel Specs Width 8 inches- 31 Offset mm
... Rear: ... New Wheel Specs Width 9 inches - 35 Offset mm
Wheel and tire specs:
Manufacturer Part Number: A 230 401 2102 2103
Front:
18x8.5 Offset = 30mm
255/40/18
Rear 18x9.5 Offset = 33mm
285/35/18
Front:
255/40/18
285/35/18
Current Wheel Specs
Width 8 inches Offset 31 mm
New Wheel Specs
Width 8.5 inches Offset 30 mm
Inner Clearance:
5mm LESS (the inside of the wheel to the strut housing)
Outer Position: EXTEND an extra 7mm (position of the outside edge of the wheel)
New Wheel Specs
Inner Clearance:
Current Wheel Specs
Width 9 inches Offset 35 mm
New Wheel Specs
Width 9.5 inches Offset 33 mm
Inner Clearance:
4mm LESS (the inside of the wheel to the strut housing)
Outer Position: EXTEND an extra 8mm (position of the outside edge of the wheel)
New Wheel Specs
Inner Clearance:
brings you here,
and for the rear:
brings you here,
and for the rear:
Yes they will fit I was running SL rims on my 99 E430. Fenders will need to be rolled.
Armani
