w210 E55 Wheels
Old Jul 18, 2007 | 12:41 PM
4runner's Avatar
w210 E55 Wheels
Was considering putting my AMG Mono's from my E55 on my 97 E420. Wheel offset calculator shows the following
Front:
Current Wheel Specs Width: 7.5 inches- Offset 41 mm
New Wheel Specs Width 8 inches- 31 Offset mm
Results
Inner Clearance: 4mm MORE
Outer Position: EXTEND an extra 16mm
Rear
Current Wheel Specs Width 7.5 inches - 41 Offset mm
New Wheel Specs Width 9 inches - 35 Offset mm
Results
Inner Clearance: 13mm LESS
Outer Position: EXTEND an extra 25mm
With that in mind would this work?
I plan to have Bilstein sport shock and H&R sport springs installed.
I suppose tires would be staggered @ 235/40/18 front and 265/35/18 rear. Of course I just noticed that a 265/35/18 is not available in the General Exclaim UHP, only a 275/40/18. Tirerack says this tire will fit. Will it?? I know there are other tires but was overtaken by the amount of positive feedback on these on tireracks website. Thanks.
Old Jul 18, 2007 | 01:02 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
I Have the AMG E55 Mono Blocks with the 245/275 on my 2000 W210 Wagon..No Problems..NO Rub
Also I Used H/Rs with 1 Bump spring pads and Bilstein Sports in the front as the rear is self level
http://mymbonline.com/forum/uploads/dsc06714_140.jpg
Old Jul 18, 2007 | 01:03 PM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
They will fit without any issues as Mark mentioned...
Old Jul 18, 2007 | 02:08 PM
4runner's Avatar
Thanks guys, I'll look into the 245/275 tires.
Old Jul 18, 2007 | 04:23 PM
ProV1's Avatar
MB, BMW
what rims are u gettin for the E55?
Old Jul 18, 2007 | 09:41 PM
4runner's Avatar
HRE's...should be here in a couple of weeks. Thanks again for the oil filter, smooth and painless transaction, just how I like it.
Old Jul 18, 2007 | 11:14 PM
ProV1's Avatar
MB, BMW
oh i forgot about that.. lol no prob
post pics of the E55 when u get the rims
Old Sep 5, 2007 | 06:58 PM
ricoh64's Avatar
'99 E 430 , '05 E500
Has anyone tried a 245/45/18 in the front?
I currently run 245/40/18 on Carlsenn's no problem but would like a bit more profile (e 430)
Any issue?
Old Sep 11, 2007 | 09:43 PM
Britrover's Avatar
01 W210 E Klasse | 02 W 463 G-Wagen | 06 Land Rover LR3 HSE
Hello All - I have a 01 E430 with AMG E55 wheels (Front Tire is 245-40-18 and Rear tire is 275-35-18). The front tires rub (i hear it more from the driver side front tire)....the rears don't rub.
I was told to swap the front tires to 235 as the front of the E430 / E320 is not the same as the E55....in other words stay away from the 245 if the rubbing wil bother you.
here is the link to my thread (https://mbworld.org/forums/e-class-w210/207928-tires-rubbing.html)
Old Sep 11, 2007 | 10:01 PM
raymond g-'s Avatar
99 E320
Brit-with the 245 front, where was the rubbing occuring? on the fender lip,
or the inside of the tire ie suspension rub?
Old Sep 12, 2007 | 07:24 AM
Britrover's Avatar
It is rubbing from the inside......it only happens when the front shocks encounter a full compression due to a dip in the road.
I was told the E55 stock wheels/tires would work without any rubbing but this problem drives my better half insane
Old Sep 12, 2007 | 10:16 AM
raymond g-'s Avatar
99 E320
interesting. i have the E55 front on my 99 E320. the wheel well lip touches
upon deep compression and I've already rolled the lip, so I'm going to try
moving up one pad# and if that doesn't handle it (or the gap too extreme
for me), will go with narrower tire.
sounds like your rub may be that notorious nut you think?.....
(photo from E55 KEV found in the archive)
Old Sep 12, 2007 | 04:49 PM
Semikolon's Avatar
2001 E220T CDI Avantgarde, 2002 E55T AMG
you better learn her how to drive then. high speed and braking over holes and bumps like that should be avoided. full compression of the shock will kill them sooner than you think. it may also cause her to lose control over the vehicle, whether the tires rub or not.
Old Sep 12, 2007 | 09:42 PM
Britrover's Avatar
Semikolon – I’m actually a conservative driver and don’t push the car. However the roads in NC,USA have a lot of dips (nature of the roads here). The problem I have does not have to do with my driving or the compression of the shocks but the size of the front tire. I never had this issue with the stock 17 inch tire/wheel
Per another member on this forum ‘The overall diameter of the 245-40-18's is 25'7...your cars
recommended diameter is 25'3...so your front tires are 4/10 of an inch
larger....plus the offset on the front rims is +31...that puts the tire
almost flush with the inside of the fender well....if you want to correct
the problem you need to change to a 235/40/18...the overall diameter
is 25'3...which is factory spec....plus this will correct your odometer
reading...i would stay with the 275/35/18's in the rear’
Old Sep 12, 2007 | 09:45 PM
Britrover's Avatar
raymond g - Thanks for posting the pic. I think it might be the nut, I had my mechanic look at it and he suggested just putting on the 235's once the 245's wear out as the 245's are pretty tight on the E430
Old May 13, 2009 | 02:15 PM
daytonabeach's Avatar
S212 2014 220 CDI
Hi!
New owner here
I wonder if a set of E55 Carlsson 19" will fit my W210 SW as good as the 18" mentioned above here, or if they have a different build?
Its the same as these
Thx
Old May 18, 2009 | 04:27 AM
VirenderBains's Avatar
E320 CDI
Will it fit?
Hi,
Does anyone know if I run this setup on my E320 CDi W210:
255/35/r20 CLS AMG Rims. The 5 spoke model. Offset is 43
Kind Regards,
Virender Bains
Old May 18, 2009 | 09:32 AM
ohlord's Avatar
No
don't do it
Please
Old May 18, 2009 | 09:42 AM
E320 CDI
haha, how come?
I set eye on a set of Kahn rims
8,5 X 19 offset 30!
These should fit perfectly.
Old May 18, 2009 | 10:37 AM
nsupra's Avatar
would 235/40/18 and 285/35/18 work or would the speedometer be off? On a set of E55 monoblacks.
