URGENT **** Wheel Experts - Help Needed ****
All,
I have looked at forums and done preliminary work - however I am no wheel expert and need help on this. I have a 2000 E55 (W210) with original rims...
Looking to put on Vossen VVS075 Wheels. 19x8.5, 19x9.5 (both with 32 offset).
Wheel Offset Calc says...
Fronts...
Inner Clearance: 7mm LESS
Outer Position: EXTEND an extra
Will this work without rubbing? And if so, any guidance on rubber?
Regards,
Double -A
Fronts...
Regards,
Double -A
monowiper
that should work, that's same size as BBS LMs
as far as rubbing goes, is your car on coilovers?
different tires have different sidewall profile, for example a Pirelli has more rounded sidewall, whereas a Bridgestone has a very fat sidewall
going with a rounded one eliminates any chance of rubbing...
Eurosport,
No coilovers - original suspension (to be dealt with soon also). Working on General tires... (worked for 2 other cars in th house).
Thanks and Regards.
Double-A
Thanks and Regards.
Double-A
