E 55 handling issue
What tires are you running?
Your lower ball joints & upper control arms may be worn out too which can cause that as well. Until you repair these two components there is no point in doing an alignment b/c it will immediately get out of spec the second you start driving down the road. Its not your springs / shocks (although those do settle over time, that's not why you are rubbing while turning, its b/c your suspension geometry is complete out of whack due to worn steering components).
Hope that helps
These systems are meant to save you in case of driver error or loss of traction. Hopefully you don't do it just to see the orange triangle in your dash.
You're driving a 4k pound Autobahn cruiser not a WRX.
