Still Not the Same Brakes
1. Opens internal bleed ports in the ABS
2. Forces all the air in the lines that run vertical, to go against nature and flow down and out, by means of pressure and overwhelming volume.
You have had this for some time now.
https://mbworld.org/forums/w210-amg/...-question.html
For some reason I got an idea that maybe there is/was an issue with the ABS or something that it controls, so I headed to a deserted farm area where I normally do runs with others. I floored it to anywhere between 60-80 and then slammed on the brakes activating the ABS to a complete stop about 4 times. Each time the pedal feel hardened and pedal travel decreased.
I've been driving for a week now and the brakes are working properly like they should have all along. I have not done anything with the brakes after my last first post in this thread.
Could hard braking and activating the ABS force fluid into the vertical lines per Yacht Masters suggestions? Any other possible explanations for this?
