Brake Bleeding question
I am trying to flush the brake fluid , I am fairly familiar with the procedure, ( or am I ? ) ...logging onto Alldata I see the following in the procedure:
- Actuate the Master Cylinder Switchover valve. ( see attached diagram ) . Could someone explain that to me please? I thought we just hook up the power bleeder, set the PSI 15-20 PSI and thats it.
- Also, it says to pressurize the system to 2 bar, thats 29PSI, is that a mistake, I thought we couldnt go over 20 with our cars, I am not even sure that the cap which came with the bleeder can hold 29PSI.
Advise and comments are always welcomed and appreciated. Regards,
Max
Max
I flushed my AMG brake system using the power bleeder. Don't need to open any Master Cylinder Switchover valve
. Just fill the bottle with one liter of brake fluid, (I use ATE super blue brake fluid) it take about one liter to flush the systems. DOn't let the bottle run dry or you have to start over. Than pump it up to 2 bar like it said, about 30psi. and start bleeding the lines; right rear, left rear, right front and left front.If this is the first time you flush the E55 brake lines than one or more of the bleeder screws might be rusted out, clogged. My front left was clogged and rusted, i had to remove it completed and unclog it. Pretty basic and very easy.
Happy New Year to you and all our friends .
Max
They play with high end car like Mercedes, Porsche, BMW, Aston Martin, Lambo they even have a Koenisegg CCX in the show room and the don't own a power bleeder
i was worry they might wear out the brake switch
The old school pump the pedal will not move enough fluid at a fast enough rate to over come the vertical rise in the brake lines coming out of the ABS unit (air remains trapped). Secondly it is necessary to use a power bleeder at the 2 bar, 29 psi to open the check valves in the ABS unit as well. For the people that claim the old school worked fine, that is because they never had any air in the system, however if air is introduced you will defiantly need a power bleeder. My dealer introduced air in to my system and after a year with a spongy pedal I bled the brakes 4 times the old school way with no improvement in the pedal feel, then I gave in to the power bleeder, all good now. Don't do as I did.
I think I am going to build my own thing , there has to be a better way ...great aluminum cap with the right gaskets, an air pressure regulator, hooked up to an air compressor, that should be easy, now I am thinking of how to implement the tank to hold the fluid . You can do all the above real easy if you are just bleeding, but flushing is slightly different.
We bled brakes at 2Bar with no problems
For Home I set the regulator to 2bar on the air compressor with a good water trap and use a MB Metal cap fill the brake fluid tank and bleed one corner at a time...PITA but it works
SBC cars are different
Pardon me but what are SBC cars? and what is a water trap? excuse my ignorance! By the way, I did finish the front bearings and everything sounds and feels fine ...so far! Thanks for your support and guidance.
SBC was entered into The Mercedes Brake system on the W211/R230 and Maybach Sensotronic Brake Control (SBC) Mercedes dropped SBC in 2007 on model update W211s
Water trap is a MUST when you have a Air Compressor ..It prevents moisture from getting in the Item you are using the compressed air for..
As ANY Moisture in the Brake System will cause damage
I Use a Basic trap then a filtered trap ..yes 2 to prevent moisture
Best regards
Nick
You're moving the piston way beyond its normal operating tolerance. Debris seems to build up over the exposed area and consequently has the potential to mess up the seals. I've seen this happen on numerous occasions.
It may or may not happen. I just think with a car like a Mercedes, don't take a chance and pressure bleed it.
http://www.ultimategarage.com/shop/p...oducts_id=2123
With this setup , as Mark rightly corrected me , one would need a water trap/ filter , to remove the moisture from the air flow coming the compressor , that can be found from several sources , from $25-$80. If the cap from Ultimate garage is as good as it needs to be, that setup should be great.
Then I found this product:
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_500wt_1399
I emailed the gentleman ( aerospace engineer ) who designed it and now fabricating it, and he seems quite nice . what I like about his design , is its simplicity, and it does seem to be very well made. He also said that the biggest problem is in the cap itself, making it pressure tight is very important which I agree. His uses a O ring seal (? ) .While several sites claim that pressure needed is 15-20 psi , our cars and I would imagine several others need 29-30 psi. My concerns about his design is :
- Using air from the tire. He claims that if used and connected properly, one can bleed four corners with a loss of 0.5 psi to the tire!!! ( I have nt verified that of course). But even if that is true, then what about moisture, I know that air compressors do in fact introduce moisture in the air tank, but what about the air from the tire? The designer states that the air in the tire is dry.
- That design may work well for bleeding , but what about flushing? I dont know the exact capacity of his canister ( I will get that ), if it is not big that means that the system will be opened up again to refill , releasing the pressure, and even if it was big enough , will it hold the pressure long enough for a flush job?
I still think his design is elegant and simple, the fittings seem very well made. And if we could verify few things , maybe there is some interest in a group buy. I might consider being the first one to try it, and report , but I would to hear your comments.
