Oil Change/Service A
After doing a bunch of reading on the forum, I decided to do the oil change and service A on my own. I have all the parts I think I need below (except for the cabin filters, which I'm not changing for now), but the part I cannot find is the 4 O-rings for the oil filter kit. Does anyone have a part number for these or know of a place where I can buy them?
The parts I'm buying for the oil change/service a are the following. Please let me know if I'm missing anything:
2 - Mann air filters
1- Mann fleece oil filter
9 - Quarts Mobil 1 0w40
1 - Oil drain plug gasket
4 - Oil filter O-rings (?)
Your'e
missing the topsider or similar evac unit to suck the oil out the proper easy way.
When you get done jacking it up the hassle of the drain plug
the time wasted when you could have simply done it all without crawling under the car you will think why did I not spend the one time investment in the proper tool.
diy www.peachparts.com
resource section diy articles way down at the bottom of the page oil change #2
Napa carries the Mann fleece filter packaged in their Box part #7078
includes the o rings
Thanks for all the recommendations. For now I'm going to do it the difficult and improper way by pulling the plug, but once I get frustrated and realize I should know better, I'll probably end up buying the extractor!
2001 E55 - 2008 CLS63 -2016 F-150
did basically same as you except i stopped in local place and asked how much they said ten bux if i got my own stuff said WTH .. ten minutes and ten bucks and i was outta there fresh oil fresh filters
