Need help on wheels
Old Dec 29, 2010 | 10:41 AM
Tman22's Avatar
1999 E300TD
Need help on wheels
I have a 1999 E300 TD. Will these monblock wheels fit on my car with no issues?
Mercedes Benz Wheels and Tires
Continental Conti Pro Contact
245/45 R 18 96H
18” AMG Wheels:
MB symbol HWA 1404010102
8.5 x 18 H2 ET47
Austria
Old Dec 29, 2010 | 02:35 PM
ruBENZ's Avatar
2000 E55 AMG
Depends on your current OEM offset. Generally, if you are within +/- 5mm you should be fine. Also, MBZ uses two different sized lug bolts: 12mm and 14mm. Do you know the OEM figures?
Old Dec 29, 2010 | 02:45 PM
Tman22's Avatar
1999 E300TD
No I don't. I was told these would not fit right. I'm looking for a set of AMG wheel to fit my 1999 e300. so if anyone has any please shoot me a line.
Old Dec 29, 2010 | 02:46 PM
Tman22's Avatar
1999 E300TD
what year is yours and what do you have on your E class?
Old Dec 29, 2010 | 02:56 PM
ruBENZ's Avatar
2000 E55 AMG
ET47 did seem a bit high. If you remove one rim, you will see the ET# stamped on the inner rim. I am guessing your OEM offset is in the 35mm range. If I am correct, then W210 E55 AMG rims (offset: 31ET front/ 35ET rear) should fit. Also, you may need lug bolts specific to these rims: (12mm x 1.5 x 40mm).
Old Dec 29, 2010 | 02:59 PM
ruBENZ's Avatar
2000 E55 AMG
2000 W210 E55 AMG with Brabus style rims: 245/40/18; 31ET front + 275/35/18; 35ET rear.
Old Dec 29, 2010 | 03:06 PM
Tman22's Avatar
1999 E300TD
do you have full side view of yours so I can see what those look like? where do I find them?
Old Dec 29, 2010 | 03:17 PM
ruBENZ's Avatar
2000 E55 AMG
Ebay. Eurotech Wheels.
Old Dec 30, 2010 | 09:29 AM
Tman22's Avatar
1999 E300TD
I need a set of 18x8 31et. Monoblock II would be good AMG.
Old Dec 30, 2010 | 10:40 AM
desired_speeds's Avatar
2007 SL55 AMG
I may be interested in selling my set in the near future if I can find another set of rims I like.
Old Dec 30, 2010 | 12:29 PM
Tman22's Avatar
1999 E300TD
Are they 18's? and will they fit a e300?
Old Dec 30, 2010 | 01:04 PM
ruBENZ's Avatar
2000 E55 AMG
Here you go. And they will fit. The required lug nuts are 12mm x 1.5 x 40mm with ball seats not acorn.
http://cgi.ebay.com/ebaymotors/MERCE...#ht_3488wt_937
http://cgi.ebay.com/ebaymotors/MERCE...#ht_3446wt_937
Old Dec 30, 2010 | 01:22 PM
Tman22's Avatar
1999 E300TD
thanks
Old Dec 30, 2010 | 06:56 PM
2007 SL55 AMG
yea, they're stock E55 monoblocks.
