Launch control
Old Feb 13, 2011 | 10:37 PM
aquasition's Avatar
2003 E46 M3 1982 308GTSi 1972 P1800 1970 Charger 500
Launch control
This may really be a "quick"...question.
How to do a burn-out on a w210 E55?
Thanks,.
Old Feb 14, 2011 | 12:20 AM
jrt78's Avatar
2000 E55
Turn ESP off (it doesn't fully turn off but thats a different thread) shift trans to 1 and stomp on the throttle! p.s. be prepared to upshift it will come fast!
Old Feb 14, 2011 | 03:20 AM
desired_speeds's Avatar
2007 SL55 AMG
:S
Old Feb 14, 2011 | 07:26 AM
saintz's Avatar
GL450
You want to launch or burn out? ESP off, power brake (left foot brake and right foot gas), rev and release the brake. That will spin the tires and either launch you or burn out, depending how much gas you give it.
Old Feb 14, 2011 | 07:36 AM
aquasition's Avatar
burn out
Yeap...there's more like it Saintz.....a controlled burn out. It seems easier than it is on my M3. Thanks. I know how to do it....all I'm missing now is the car....lol. But....it's coming soon....keeping my fingers crossed...
Old Feb 14, 2011 | 09:45 AM
saintz's Avatar
GL450
The E55 has almost twice the torque of an M3. Even with traction control on and barely gassing it, if you power brake you will spin the tires.
Unless you're at the track with slicks, you'll probably get a faster launch by easing onto the throttle. Power braking really is going to spin and in my experience it slows you down.
Old Feb 14, 2011 | 11:36 AM
tsquare's Avatar
AMG 2002 E55, 1997 E320
Thanks,.
If you turn off the ESP, you will not need to power brake to do a burn-out. Just, put car in "4" (I believe this is the "sport" mode for the transmission) and "hit the gas pedal hard" the tires will break-free .
Old Feb 14, 2011 | 12:04 PM
saintz's Avatar
GL450
S mode (on the S/W switch) will start the car in 1st gear, which is what you want. You don't need to manually select the gear.
Old Feb 14, 2011 | 12:52 PM
Anatoly's Avatar
2001 E55 AMG
Can someone tell me how to turn ESP completely off?
Old Feb 14, 2011 | 12:57 PM
jrt78's Avatar
2000 E55
Can't turn ESP completely off!
Old Feb 14, 2011 | 02:56 PM
Anatoly's Avatar
2001 E55 AMG
^ I know in later models you can, I think you push 3 times the "R" button and then it gives you the menu where you can turn it completely off, our cars don't have that option?
Old Feb 14, 2011 | 04:37 PM
saintz's Avatar
GL450
The only way to truly turn ESP off is dyno mode. This is only on the newer models. No one has found a dyno mode on the W210, as far as I know. Dyno mode is not something you could use on the street, anyway, as it also cuts the ABS and basically makes the car, as Jeremy Clarkson put it, an axe murderer.
Old Feb 14, 2011 | 05:29 PM
Anatoly's Avatar
2001 E55 AMG
^ Thank you for the information.
