Can the Lysholm SC be dropped in a 2002?
2002 MB E55 AMG
Just for fun, does anyone know if this is possible? Advisable? More/less $$ than Kleeman?
I'll bet some other enquiring minds want to know!![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
TJC
TJC
Has it been done? Yes. This thread will tell you *most* of what you wanna know.
https://mbworld.org/forums/showthrea...ght=cannonball
2002 MB E55 AMG
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
That Renntech SC (high boost) is about $37 K I think. Some of us DO have budgets to consider ...
For instance, anyone familiar with this?:
http://www.myhps.com/e55/e55.html
Jeff
Jeff
![](https://mbworld.org/forums/images/ranks/veteran_air_force.png)
Re: Renntech $upercharger
Jeff
Jeff
https://mbworld.org/forums/forumdisp...?s=&forumid=40
Always quite a fight over HPS & Kleemann Superchargers. Frankly, too many arguements over which is best. The arguments are useless because each product is different and priced for individual budgets.
Guest
Posts: n/a
Jeff
Jeff
We use a roots designed compressor that generates low boost and high torque output at low engine RPM to eliminate supercharger “Engine” lag and increases engine torque and HP output at low speeds and throughout the entire engine speed range to redline.
It generates up to 4 pounds of boost utilizing a highly efficient intake and discharge system that increases airflow without increasing supercharger discharge air temperatures. This low boost/high efficient system eliminates the need for costly intercoolers and increases reliability by not requiring redundant systems reducing failures.
We use a Air/fuel ratio and data acquisition system for measurements. It is a multiplexed data acquisition system. It’s the only system that includes data acquisition with temperature compensated air fuel ratio measurements. This system provides 19 channels of data acquisition, 14 are programmable analog inputs: Voltage, pressure, temperature, TPS, MAF, and etc. Not to mention a temperature compensated lambda probes and displays the air fuel ratio.
Last week we had a performance test on our E430 driving 90mph for over 50 minutes and data being taken at speeds above 135 mph. Data showed an increase of 18-22 degrees. This data is critical to prove intercooling is not necessary for our system.
Cost including all hardware, factory warranty, CARB certification, and installation is only $9,995 dollars.
If you’re interested in our product, give me a call.
Thank you.
Guest
Posts: n/a
Re: Re: Renntech $upercharger
Originally posted by HPS (Adam)
tjcMBE55AMG,
We use a Dak 1 Air/fuel ratio and data acquisition system for measurements. It is a multiplexed data acquisition system. It’s the only system that includes data acquisition with temperature compensated air fuel ratio measurements. This system provides 19 channels of data acquisition, 14 are programmable analog inputs: Voltage, pressure, temperature, TPS, MAF, and etc. Not to mention a temperature compensated lambda probes and displays the air fuel ratio.
Thank you.
tjcMBE55AMG,
Thank you.
