Missing pixels on my temperature display
Old May 4, 2011 | 11:59 PM
snooozie's Avatar
86 190D (Exported to the Nerderlands), 87 300TD (Sold), 82 Ford F150 3spd, 99 E300D (RIP), 02 E55
Can someone show me (diy) how to fix the missing pixels on the temperature display? Or show me a link where to go to get this information. Thanks.
Old May 5, 2011 | 06:32 AM
DRBC43AMG's Avatar
DIY climate control display
Here goes from some neighbours: https://mbworld.org/forums/c36-amg-c...trol-unit.html
Old May 5, 2011 | 07:50 AM
ChaseMark's Avatar
2010 Toyota Corolla
You need to basically make better contact by pressing the wires down. Try pushing small rubber wedges between the ribbon cable wire and the socket rear. Read it somewhere...should work.
Old May 5, 2011 | 08:11 AM
snooozie's Avatar
do you go under the cover at the pedal well up or you just pull the speedo cluster from the front. I have change instrument clusters and blubs in a 123 300D wagon years ago by just opening the front plastic cover on the instrument cluster.
Old May 5, 2011 | 09:39 AM
cudaized's Avatar
2002 E55 AMG Obsidian Black with Charcoal
Here is a link to the other web site. Look in the INTERIOR ELECTRICAL section.
http://www.benzworld.org/forums/w210...-lighting.html
I took mine out. Easy to do. Steering wheel all the way out. I removed the fuse panel cover on the driver's side of the dash (by the pillar). Had access to the one screw that held the speaker grill on the top of the driver's side of the dash pad. Removed all of that and pushed out the instrument cluster with my hand. No need for those special cluster pull tools.
Here is a pdf from the other site. I can not take credit for this, but it is easy enough to tackle on your own.
File Type: pdf
Old May 5, 2011 | 06:25 PM
snooozie's Avatar
Thanks for all the information. I'll try to pull the cluster this weekend weather permit. I really dont think it's that difficult unless I screwed up some other parts while working on this project.
Old May 6, 2011 | 05:05 AM
ChaseMark's Avatar
2010 Toyota Corolla
Sounds like you have a plan. Good luck!
