New Headlights for 2001 E55
If they are broken, you can replace with real Mercedes ones off eBay. Make sure they are for HID (regular models won't fit) off an E55 or some equipped E430. Also, the pre-'00 and post-'00 are different fits.
If you're trying to go with projectors, like Depo, you need custom made lights. You can't just put HIDs into the Depo projectors, you need to use proper HID projectors. Example:
https://mbworld.org/forums/e-class-w...rojectors.html
My lenses are cloudy and I got a kit recommended here to wet sand and buff (about my limit technically) but it only cleaned them from yellowish to whitish and left sanding marks on the lenses that now look stipid. And I followed the directions to a T.
I was going to get new headlights from the dealer but they want a couple grand for a pair! I looked on ebay but nothing was available for my 2001 MY E55.
Thanks for the assist though.
Did you use a hand kit or drill adapter kit?
You can sometimes find pre-made Depo kits for the HIDs. Check with Zam2000 on here or look in the classified.
Plast-X with either super fine grit or a Magic Eraser or even paper towel should help. Finishing the polishing job will be easier and cheaper than new lights, and should look good once you get it done. You can also go to Walmart and they'll polish them for you for $25, I believe.
My car is a 98, so once again, is this shop trying to scam me for more labour $ or not? Thanks.
On the post-'00, the bumper is one piece and covers the headlight screws.
