Euro springs delivered
Gert's shipment of the brand new Euro spec springs arrived today. I also bought 4 of the #1 spring pad (shims) from MB. I do not know what shims are on the car currently - but I am assuming #3's.
I am staying with the stock shocks
My car currently sits 27".... from the ground to the highest point in the fender arch... in it's stock configuration. I am expecting a 1" drop from the springs and a .66" (16mm) drop from changing the shims....1.6" from the whole excersize.
Is this too much? Will it rub? I am not wanting a slammed look. Should I stay with the stock pads?
opinions?
opinions?
2001: Supercharged E55 AMG
Hi!
I'd say go for the 1# pads This is my car with my Euro springs (Stock) and 1# in the back and 3# in the front before i put coilovers on it. No scratch or nothing with that setup!! Good luck!
86 190D (Exported to the Nerderlands), 87 300TD (Sold), 82 Ford F150 3spd, 99 E300D (RIP), 02 E55
euro springs
opinions?
opinions?
Gert in Belgium. Here is his email explaining the process.
I can offer 1 set for 390 Euro shipping included & 2 sets at 740 Euro shipping to the US included.
We need 4-5 days to get the parts in stock. Shipping usually takes 3 days.
If you like to order, please use our secure site.
https://www.carnewal-europe.com/secu..._secorder.aspx
You can copy/paste my quote in the order field.
Once I see your order , I will send you an email back with the confirmation.
I am looking forward to handling your order.
Let me know if you have any other questions.
Thanks,
Gert.
Carnewal – Porsche styling, performance and accessories.
www.carnewal.com
info@carnewal.com
Vijverbeek 8
9688 Maarkedal Belgium.
Tel : 0032 55 499.300
Fax: 0032 55 499.311
why # 3's in the front? was your stock with 3's all around? I bought 1's for all 4 wheels
Thanks for the quick reply. The price is steep. That's euro vs usd. Wonder if the dealer would order the springs if I give them the numbers. Maybe I'll look into H&R.
2011 GL550, 2004 Audi S4 v8
Hmm, you just reminded me. I still need to get #1 pads and install them. Not sure if anyone else has #1 pads with stock springs and shocks. I might be the first when I do it....If someone has them speak up please
#1 pads
Wonder how much drop would the #1 pads do for a stock spring and shock set up??? 1/4 inche?
Pad drop
That's not bad. I'll take the .63in and keep the original springs and shocks. I was told that over time the aftermarket springs like H&R will get lower. I really don't want the car to look squady (with the wheels arching outwards).
I wonder how hard is it to compress the springs and change the pads. Is this a do able DIY weekend job? I had a spring compressor which I use a couple of years back with my 87 300D. Is the setup of the W210 similar with the W124? If thats the case I might be tempting to change the pads myself.
Euro spec springs and #1 pads installed. Measuring from ground to the highest part of the wheel opening, I went from:
27" to 26" in front
27" to 26.25" in the rear
I will let it settle for a few days and measure again.
27" to 26" in front
If you have the right compressor, it can be done in 1/2 hour
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Can't you get the Euro spec springs from an MB dealer in the U.S? I found Euro spec springs for my C43 from 2 different MB dealerships in the U.S. and they were $70 a piece
What size spring pad does the E55 come with stock? The C43 came with #1 pads stock so I would assume the E55 would as well
