Anyone tried to put a W211 motor/trans into a W210?
Alexke55amg (08-23-2021)
Thanks for the info. IF I was going to do it, I would do the install myself. I am guessing $3,000 of that would be labor? So about $7K?
And it fits?
Plus the W210 weighs 3700 lbs while the W211 comes in at least 4050. That's 350 lbs at least. The supercharger and intercooler obviously shave some of that but not most of it.
And it fits?
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
And it fits?
And it fits?
Before you set out on a project like this, drive a W211 AMG for a week.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
jonthondrkness (01-31-2022)
maybe as a hobby on your spare time....i would not mess with it. why? you can get a W211 for a very resonable price now...
GL450
Rear turbo would be a better idea. Tuning is still the problem.
Now if someone can fit the V12, that would be cool. I know someone on here has a W211 V12, but don't think a W210 V12 has been tried.
Here and you will see more vids at you tube,
http://www.youtube.com/watch?v=k0e-R...e_gdata_player
Back in the late 90s the ECU / TCU were much easier to intergrate when doing an engine swap, and these swaps were year to year appropriate. Note Brabus, Carlson, Kleenman, RennTech have not to my knowledge swapped the E55K in any form. I think the V12 in to the W210 would cost less and be a better choice.
The W211 V12TT 600HP
The W212 V12TT 700HP
And again the engine (mechanical) swap is easy the ECU is the problem, where the engine goes so goes the ECU, the entire car is controlled by the ECU don't forget the E55K has electric brakes, two batteries, Airmatic. Many components have to be married with a STAR you can't just un-hookem. To do an engine swap requires many electrical sub systems to be transfered too. Who wants to spend 100s of hours to transfer the wire looms and sensors, instrument panel, install subsystems the 210 doesn't have. And this is not just the 55K all the newer MBs are this way. Gone are the days of the DIY engine swap.
Now it is more important to buy the car you want, and not buy the car you think you can make.
And then there is the financial side, sell a clean E55 put the $10K (reality $15K) you would have spent on an engine, trans, ECU, TCU, harness, exhaust, drive shaft, fuel pump, IC & pump. and buy a W211, done and driving around in one day.
GL450
I guess I'm curious why the V12 would be any easier to transfer than the 55k. Or maybe it's just that people are willing to pay to swap a V12 into an E, but not willing to pay to put an 55k into something else (like a W210), given the costs are probably similar.
Yes the W210 non turbo V12 was 540HP
disable the need to actually have that other system hooked up, say the suspension. Just force values that enable the system. The engine and trans can certainly act independently of the auxiliary systems they just need to be cut free software-wise. I am nearly certain that an engineer that codes ECU logic, could easily recode to enable the ECU to work in whatever fashion is desired as the engine routines are already done and do not need to changed, just enabled.
I just wonder though that if a shop can do a custom ECU "map" why couldn't they get into other places in the system and hard code values to
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
It's just for novelty and educational fun. Plus, once one figures that out, the possibilities grow. Like taking that power plant and putting into other makes and models for some true custom cars.
Plan: Drop in '03 CL55 motor/ Trans, All AMG brake set up (8 and 4 pot binders) grabbing custom 14' slotted discs tucked inside 18's in this near 50 yr old car. Got to have the whoa for the go!
2002 Mercedes-Benz E55 AMG
wat u mean not tried ? Wat about the w210 Brabus wit a 7.3 V12 in that baby
