For anyone that wants to change foglight
2001 E55 - 2008 CLS63 -2016 F-150
I didnt mod anything , but changed the cracked lens oem foglight housing for a brand new one
http://www.autohausaz.com/search/pro...01&cid=13@Body, Trim %26 Lighting&gid=15015@Foglight
So after lifting the car on jack stand , Proceeded to try n take off the skidplate FML too many screws if it was on a lift i guess would made it easier but looked like too much trouble . So i went throu trapdoor on the skidplate . unscrewed 3 mounting screws all rusted as well as the brackets . they didnt really unscrew just kinda snapped off the bottom mount broke . sliding the foglight housing thru trap door was pretty tricky but after that its gets even tricker sliding the new one in .. pretty simple thought it would be harder . I got big hands so kind of a biatch moving inside the trap door cant see nothing just go by feel . 8mm socket and some angle extensions . Now after looking at them cant stand the sight of old one as it has rock chips and seems white where the new one seem clear but black sort of . Time to order new one
Moral of this post is if anyone wants to swap out for a new housing you dont have to remove skid covers just slinky your hands in through the trap door ..
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
2007 SL55 AMG
its a pain in a the *** to get the correctly aligned flush with the front of the bumper when you reinstall it. I refer removing the bumper to mess with it. It only takes like 20 mins to remove the bumper anyways.
yea its kind of a ***** but i got it pretty good .. stil havnt aimed it yet as i have a set of 55 watt hids bout togo in there just gonna order the other side to match them up . deff agree with the bumper off its much easier .
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Armani
correct I went thru the trap door jacked on stand kinda tricky getting it out and in but it works also might help having somone holding or pullin the lensr part but I managed it alone
I used a s little 8mm wrench but angle socket would make much re easier
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
I need to remove the bumper so while I'm in there I'll adjust. Was it more of a tighten bolt 1 and align tighten type ? of fix?
yea man forget about, best to take off bumper . i just changed out my other fog like tonight . had a ***** getting it out of trap door had to undo the bracket thats screwed onto the housing while it was in the trap door . some of plugs were corroded and had to splice them instead of just plug them in . fuggin 2 fogs at $166/peice and $75 55w xenons installed ..$400 + the $500+ suspension costing me and not even done , sh*t gets costly when trying to multiple stuff . and i really wanna drop some Euro63RS style wheels but all these little BS holdin me back from cashin out on the wheels .
biggest ***** is being on your back your hands get tired , but angle socket with extensions and 8mm is all u need 3 bolts and its unscrewed.
also when doing xenons i splice them and run them threw breather slot instead of drilling cover but i think drilling cover is good cuz the back of HID bulb sticks out alot more with 2 wires compared to normal H3 bulb that has flat backing , also have the remove the negative wire thats connected to the housings since H3 bulb only comes with one wire . Fitting all that wiring and inside the cover and getting the cover tight and snug enough to slide the metal clip over to click into place is a big biiiatch also but when done and lit up look EFFING GREAT
LIttle help????
I'm new to the site but have not got any replies yet? I just got my daughter(first car) and I went to fix broken fogs H1 in 2001 E 430 non sport after getting to them the old bulbs were melted in the socket so I had to cut the socket out thinking I could just take it to the local parts store and get a new one! All anyone has is H1 sockets with only one pigtail wire on our car I cut two wires ???? Can I bypass the other white somehow or is this a part I need to order from MB??
2002 E55 AMG, 1999 E55 AMG , Audi allroad 2.7T sold ,08 Jeep SRT8 sold, 06 TBSS Sold
I have to do this also , on both E55's, Mine is cracked and my wife's Housing is busted. Just ordered replacements from ECS tuning , i searched around and found them for $120.00 . I usually order my parts from Germanautoparts but they could no match the price.
h1 socket to work but I guess I will just have to pay the money!!
