brake vibration!!! help
i pull over turn the car off and turn it on error is gone and take the car home (as im goin home this would happen a couple more times)
i swapped out the brake switch last night and took it for a spin and no errors but i still get the pause and vibration in the pedal...
should i re-bleed the brakes? or is this a problem with the whole abs unit?
