R230 SL Brakes on W210
06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
I read somewhere that the Brakes from the SL R230 are direct bolt on on the W210 E55 , can someone verify this please if you know, or direct me to a link that shows that . I now about the wheels clearances and all , I also know that the R230 brakes are trailing whereas the W210 are leading , but that a minor issue as long as the rotation , direction is a the same , I am mainly concerned about the spacing and threading size of the nuckle where the caliper is mounted / attached. Thanks
