One front tire worn on the outside.
When I bought it the tires were pretty shot so I put on a full set of Eagle F1's and had a wheel alignment at what I thought to be a decent shop. They said I had a little too much negative camber on both of the fronts, but the rest was good.
Anyway, I've noticed now that my front passenger side tire is badly worn on the outside edge. Drivers side is pretty even, as are the rears. When cornering on full or close to full lock with that tire on the outside, I have noticed the problem tire 'jumping'. I don't know if it's only just started happening though or if it's taken me this long to notice it.
What might cause this? I put on two new bottom wishbones, Mercedes camber bolts, ball joints, upper arms, sway bar links and bushes and bilstein shocks before I had the alignment done. The only parts not changed were the track rods/ends because they felt fine.
I've just been out there and shaken the hell out of the wheel and cannot feel any play in the joints.
If there was too much toe in, I would have expected both of the front wheels to have bad outside wear, not just one.
The car is slightly lowered, and both of the front springs look in tact and have the same thickness pads.
I'd like to try to get to the bottom of this problem, so any suggestions would be appreciated.
My left front tire is shot due to having a slow leak at the valve stem and running with it low too often.
