slightly bumpy
Old Dec 27, 2011 | 08:06 PM
Drewloera's Avatar
2000 w210 E55
slightly bumpy
Recently Ive noticed my car become much bumpier than I ever remember it being. I was attributing it to the recent work on the freeways, But I alteady ruled out that possibility. Seems more noticable at high speeds i can literally see the whole dash and seats shake it dosent feel to bad but it is very annoying. Just replaced motor mounts, and did my front rotors. My rear tires are getting kinda worn can this be the cause.
Old Dec 27, 2011 | 09:02 PM
armaniE55's Avatar
2012 CLS63 AMG
90% chance it's your flex disk. Also did you buy OEM rotors? Do you notice it more when the car sits overnight and then you hit the highway?
Put the car on a lift and check the bolts on the flex disk, if you can see rust/brown lines coming from the bolts then it's a sign the the flex disk is going bad.
Armani
Old Dec 27, 2011 | 10:13 PM
Drewloera's Avatar
2000 w210 E55
Yes everything oem, was on a older fourm assessing the issue and I think it might be tires my rears are looking like nascar slicks...lol I hope it is just that....
Old Dec 27, 2011 | 10:35 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Have you hit any nasty pot holes? You might have bent a wheel.
Old Dec 28, 2011 | 01:53 AM
Drewloera's Avatar
2000 w210 E55
I live in LA. Potholes everywhere ..
Old Dec 28, 2011 | 12:23 PM
armaniE55's Avatar
2012 CLS63 AMG
LOL, well I would start with new shoes and have them check the rims / high speed balance.
check front end bushings,ball joints, wheel bearings, sway bar links, tire rods,etc etc
then
B. Flex disk
Old Dec 28, 2011 | 03:33 PM
maxwerks's Avatar
06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
Armani
wouldnt the flex disc only cause vibration upon acceleration only ? Not a bumpy ride ...also bent rims will cause vibration , not bumpiness ... when were the shocks changed .. at any rate , slicks in the back would cause all kinds of havoc so change these first , and go from there .
Old Dec 28, 2011 | 04:43 PM
armaniE55's Avatar
2012 CLS63 AMG
True statement on the flex disk. However my car give me shaky feel to it until I changed my flex disk. (arm rest, center console, seat shaking) annoying as hell... those flex disk can turn into rocks with age.
Armani
Old Dec 28, 2011 | 05:20 PM
Drewloera's Avatar
2000 w210 E55
Thanks for all the input going to check flex disc. Hopefully its just my rear tires
Old Dec 28, 2011 | 05:25 PM
Drewloera's Avatar
2000 w210 E55
https://mbworld.org/forums/w210-amg/337996-60mph-vibration.html
Old Dec 28, 2011 | 06:34 PM
maxwerks's Avatar
check them all , including flex disc ... I was just responding to " BUMPY " , to me bumpy has to do with shocks, joints , sway bar joints , spring perch pads ( which hardly ever fail ) , all others will vibration to a degree or another . best of luck
Old Dec 29, 2011 | 12:20 PM
armaniE55's Avatar
2012 CLS63 AMG
Thumbs up
+1 and most important let us know of your findings
gl
Old Dec 31, 2011 | 05:20 PM
Drewloera's Avatar
2000 w210 E55
Just did my rear tires. They were the main culprits for the harsh ride.
