HIDs Fogs not working :( HELP!
I ordered the slim digital 35w HID kit with the error decoders from iJDMtoy. I hooked up the driver side bulb and it turned on, no error message. After installing the passenger fog light, the left one turned on for a second and then turned off, and the right one never turned on. After playing with the polarities and switching them around, I started getting the lamp defective message and both fog lights never came on again. Any one have any experience?? I'd appreciate any help!!
Joe
I went w/aftermarket bright bulbs that don't look like yellow more of a bright HID color.
GL though!
jr
Thanks for the help though guys!!
oops too late .. yea try other side , and vise versa maybe u got a DOA unit . does it say Xentec on it >?
GL though!
jr
Thanks!
honestly though once you slap hid in there its hard to go back to halogens . the biggest issue i see personaly with them is getting the negative wire to clip on the housing , I cut the bulb wires and fish them through the vent hole on the cap then solder and seal them , like that you dont have to drill a hole in the cap . but everyone had their own way of doing it
also i have leds through the whole car and some are not can-bus or whatever so I get a light malfunction but it doesnt bother me as much as it does others
maybe you have a bad ballast or bulb ..
have you ever got them to work ..
where did u test it ..
if you have another car with battery under the hood <my benz is in back seat> take the kit and hook it up leave light inside protector sheild hook it up all and run pos to pos and negative to negative and see if they power up there .. if they dont then u have problem with kit and not car
also check and see the part that plugs into the ballast somtimes you have to flip it over because the + and - might be crossed
is it ballast and bulb .. our E55 dont use H1 bulb we use H3 bulbs
are you just using the bulb .. look around for the wire that leave the foglight housing somtimes they come loose or can also rust off apart from eachother
