seafoam
Old Jun 14, 2012 | 02:06 PM
ulovemybenzo's Avatar
99 W210 E55
seafoam
has anyone done this? feedback?
Old Jun 14, 2012 | 03:27 PM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
$9 a bottle did not noticed any different.
Old Jun 14, 2012 | 07:31 PM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
Takes more...
Than one bottle. Gas tank only, not crankcase. I prefer techron and non ethanol gas, does seem to make a bit of difference, I suspect it's mostly the gas.
Old Jun 14, 2012 | 07:35 PM
desired_speeds's Avatar
2007 SL55 AMG
ive thrown a bottle into the tank before. didnt notice a difference.
Old Jun 30, 2012 | 10:17 AM
Maybe just coincidence but week after I use up 2 can of seaform I got a dead up stream Driver side O2 sensor. $18 for Seafoam and $702 for O2 sensor. I got raped by Stealer.
Old Jun 30, 2012 | 08:12 PM
armaniE55's Avatar
2012 CLS63 AMG
No coincidence. I stay away from that stuff it burns up your 02 sensors. If your just trying to clean up your fuel injectors do what I do- every oil change I drop 2 bottles of Techron on a empty tank fill up- and let it do it's thing over night. I always, always feel the throttle response the next day
*I always notice a tad better on MPG as well
http://www.amazon.com/Chevron-Techro...owViewpoints=1
Old Jul 1, 2012 | 12:09 AM
snooozie's Avatar
86 190D (Exported to the Nerderlands), 87 300TD (Sold), 82 Ford F150 3spd, 99 E300D (RIP), 02 E55
What about Redline S1 Fuel System Cleaner. You can get them at Pep Boys. I use them on my diesels with very good results. I think I'll give Techron a try since they are cheaper. Wonder if you can get them at Walmart....
Old Jul 4, 2012 | 01:42 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
There is one compelling reason to use Techron, it's MB approved.
Old Jul 4, 2012 | 02:48 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
I have used both redline (in my honda) and techron (in my C43) and had positive results with both.
I only use Chevron gas in my C43 so it is always getting Techron
Old Jul 9, 2012 | 11:48 PM
jnash's Avatar
2017 S63
Seafoam once per oil change period in your gas tank will help keep your injectors flowing nicely. Seafoam in the air intake one time will clean out any carbon deposits on the valves and piston. There are plenty of youtube's on seafoam. Done this on loads of cars some with great results, others with just some improvement.
How much it makes a diff depends on how dirty your engine is or how gummed up it is.
Milage less than 45K you may not notice much difference. Over this and you will notice an improvement over idle, pickup and MPG on the air intake. There is a risk of clogging a cat or a spark plug but its rare unless your engine is very clogged.
You will not ever notice a diff in the once per oil change period of a gas tank seafoam fill. It may take a few cycles before things just seem to run well.
Techron isnt as powerful a cleaner as seafoam.
