park sputter
http://www.benzworld.org/forums/r129...on-sensor.html
Very easy. Took me less than 10 minutes.
For the cam sensor, it's on the front of the passenger side head facing the radiator. Took me less than a two minutes to find and replace.
I am not sure about the codes. I'll ask one of my tech's.
You (probably) don't need to buy a MAF, just follow the attached PDF guide
Or you can always change the whole car...
Normally,after the install,the car should take a little longer to start until it builds back up the pressure,but not after that. If you did the install correctly and used an OEM or similar fuel filter I don't see what could've gone wrong. I believe if you didn't install it correctly the car wouldn't start at all. Or if somehow the car takes air into the system,but then the CEL would be triggered for a large vacuum leak...
If you think your problem is fuel delivery related I would check my fuel pump...and by that I mean to do a fuel pressure test using a fuel pressure gauge. There is a possibility that the fuel filter you had before was somewhat clogged and now that you've changed it,the gas flow has improved dramatically and also the pressure in the system has changed. The car can run rough because of this issue if your fuel pump pressure is too weak OR if it's too strong.
Good luck!
