One pic...
Old Jan 15, 2013 | 02:45 AM
KJI3jflarryfe93's Avatar
yes euroversion C43's came with #1 pads.
since an AMG is dropped from factory on sports suspension, now modding with Vogtland which lowers 35 mm might ONLY give me a slight drop?
not the 35mm which Vogtland claims?
what do you think about this?
been reading what the others have done on w202 AMG forum, they all use #5/#4 springpad combo to avoid rubbing issues.
using different springpads, is it necessary to do a new alignment after a each springpad test?
different springpad thickness giving different specs when doing alignment?
Old Jan 15, 2013 | 06:29 AM
desired_speeds's Avatar
2007 SL55 AMG
I'm not sure how Vogtland measures their drop, but if many others are using #5/#4 spring pads to avoid rubbing issues, I think you should do the same. Spring pads are inexpensive and aren't too hard to swap out once you are familiar with the process. It takes trial and error to get the height you want. Each specific car/ spring combo may yield different results when lowering.
Different spring pad thicknesses will raise/lower the car thus requiring alignment. Don't get an alignment until the ride height is settled and you are happy with the results. It should be a finishing touch after all other adjustments are made.
Old Jan 15, 2013 | 07:43 AM
yeah, will try different pads to get the perfect stance.
after that will I do a 4 wheel align
thanks
Old Jan 15, 2013 | 08:59 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
I want to play! Cut H&R springs, #1 pads and stock shocks (need replacing). There's virtually no gap and I haven't had any rubbing issues.
desired_speeds: Did you need to run spacers for those wheels? I love how they look and want to get some new ones for mine eventually. Figure I might keep an eye out for a cheap set on CL.
Attachment 449094
Old Jan 16, 2013 | 12:24 AM
2007 SL55 AMG
no spacers needed for the wheels, just smaller tires as they poke pretty far out.
Old Jan 16, 2013 | 12:27 AM
2007 SL55 AMG
Originally Posted by JamE55
desired,
Can you take a close up pic of the front with the #3 pads. Want to see what it looks like and how much gap with #3 pads. Thinking of maybe going this route.
Old Jan 16, 2013 | 10:28 AM
  #32
JamE55's Avatar
Out Of Control!
Thanks bro! Might have to do that once i get a new tire setup. Thinking the PSS would work perfect with #3 pads since the walls on those are taller.
