Headlight washer question
Hi all,
When I lift up the smaller washer fluid reservoir (for example, to replace a headlamp bulb), fluid starts peeing out from the connection where the pipe to the smaller reservoir connects to the bottom left corner of the larger one.
I managed to replace it and stop the leak, but before I go in and break things further, I'm trying to figure out why the two tanks are connected.
Am I right in thinking there is a single pump for both reservoirs, and this is where my leaking connection is? Or is the smaller reservoir connected directly to the larger reservoir?
Thanks!
Tim
Thanks!
Tim
