Lack of power
Bad CPS??
2002 E55 140k miles.
Usually bad CPS is only common on W202 C36 and C43 AMG. Symptoms are the car will die when it's hot and will not restart until engine cools down again (bad CPS very heat sensitive). With that said new CPS is dirt cheap and easy to replace so its not a bad idea to do it anyways while you are swapping out air filters. Mite rare for a coil or spark plug to go out on the w210 e55 engines, but if you are still running on the originals they are over a decade old. If you decide to do plugs and coils, don't be cheap and replace one.... Do the FULL SET.
My money is on MAF, as I have felt those symptoms many times before and usually you will get those symptoms without CEL until it gets REALLY bad.
