W210 Mercedes E55 AMG Project
#101
2002 E55 AMG Obsidian Black with Charcoal
M3RC3D3SE55AMG: Just curious if you have plans for the transmission?
Other members that have added the super charger have discovered weaknesses in the rest of the drive train.
Great job in sharing with us.
Ola
Ola
#103
Mercedes-Benz E55 AMG (W210)
#105
Looks good.
Looking at the front with the hood up makes me wonder if anyone has tried fitting those air scoops the w211 and M5 guys use on a w210. Seems like they would help push more air into the intake.
#107
A guy from Sweden named Magnus with his user name of ABALONE.
He supercharged his W210 E55. Used to post a lot back in 2010-2012?
Here are links to his posts:
https://mbworld.org/forums/search.php?searchid=14146391
Videos:
https://www.youtube.com/user/LJUNGWALD?feature=mhee
Tooooooo much info to list here.
#108
Ah yes! Very familiar with his work. If my memory serves me right he pushed his engine/transmission to its limits with his modifications. I'm not being as drastic as him. Looking at running a steady 500-510 myself, and again the transmission is more than capable of handling that.
#109
Brushing up on his work I see he was running a built engine. He changed the pistons (and sleeved his block no doubt), ran a smaller pulley for a touch more boost, and on top of that he pushed his rev limiter up and tuned his transmission control unit too.
Out of his list of modifications, the only things I could also do are the pistons and pulley as his car is running the newer ECU/TCU to mine. I have the 2.0 and his is the 2.8, so he can play around with mapping as much as he likes. For my car its a little more complicated.
I am considering rebuilding my block after running the Kleemann kit for a while, I'll see how things go. If I was to do further modifications, I would sleeve my block, lower the compression with forged pistons, run a smaller pulley for more boost, and upgrade the cooling system further as the "next stage".
In all honesty though, right now, I just want to take some time to enjoy what I already have.
#115
We're forcing more air so obviously need to send more fuel as you know. There are two ways to set up for this:
1. Larger injectors with stock pumps and a remap (newer system)
or
2. Stock injectors but twinned with higher powered fuel pumps, a regulator, and resistors for the MAF (older system).
We're still playing with which is the best option and I'll update on this ASAP.
#117
Is there a considerable difference between the 044 and the stock E55 Bosch pump Zayed? What is the pumping capacity etc of each unit respectively?
#119
That explains a lot then Zayed. The Kleemann kit I went with runs boost pressures best suited to the stock fuel pump pressures, and it was a stock pump they sent with the kit to run inline with the original.
#120
Looking Good!
It just keeps getting better! Great documentation.
By the way, I from what I can gather, Abalone's (Magnus) E55 no longer exists. Apparently he sold it back in August and the new owner wrapped it around a post. It's been parted out, at this point:
https://mbworld.org/forums/w210-amg/...gnize-e55.html
As much as we all loved the Magnus build, I think it's safe to say there's a new Sheriff in town now
#121
It just keeps getting better! Great documentation. By the way, I from what I can gather, Abalone's (Magnus) E55 no longer exists. Apparently he sold it back in August and the new owner wrapped it around a post. It's been parted out, at this point: https://mbworld.org/forums/w210-amg/...gnize-e55.html As much as we all loved the Magnus build, I think it's safe to say there's a new Sheriff in town now
I'll make sure I continue to the showcase work and the driving experience for you all. Just waiting for the festive holidays to pass so work can get finish of setup and tuning etc.
Really appreciate the support!
#122
Very quiet around here. Have a feeling someone is pretty busy peeling rubber! So you're saying you'll get to 500 without a build? I've got my 5.4 sitting around waiting for a tear down. I'd like to be at 500!
#123
It's spurred me to write this post now.
We were experiencing fuelling issues just before Christmas/New Years, and they were rectified to an extent, but after the festive period the car was started and we found it had developed a misfire. We're putting it down to a leaking injector at present. We're stripping the fuelling system to check, clean, and rebuild it.
I'll update the thread with more photos and videos once we've gotten round to the "fun stuff". Dyno and ¼ mile runs etc.
In other news I treated the Mrs to a surprise Birthday/Christmas gift in the form of an immaculate W208 CLK 320:
Thanks for the ongoing support people!
#124
After weeks and weeks of testing the Kleemann kit with the fuel regulator/resistor/secondary fuel pump setup, we finally gave up on that option because we simply couldn't get the car running right that way. Instead we've gone the custom ECU/mapping route.
All the relevant parts have been removed related to the option 1 setup, and replaced with the larger fuel injectors, fuel rail, and custom ECU tune from Kleemann.
I'm making it all sound quite simple, but for anyone who knows about the W210 AMG version which comes WITHOUT an OBD2 port, remapping is a difficult task in itself.
Instead of trying to re-flash the stock chip (which if can go horribly wrong, rendering the ECU useless), we bought a blank chip and loaded the custom Kleemann tune onto it, making sure the stock chip/tune stays intact for future use or reference.
The stock chip was then un-soldered/removed from the ECU's main board, and the tuned chip put in its place (which is the process seen in the photos).
The car fired up first turn of the key after the tuned ECU was refitted.
Now we just need to double check air/fuel ratios and make sure everything is as it should be before heading to a Dyno for final performance tests.
If the air/fuel numbers don't quite hit the mark, Kleemann are on call to write another tune for the car, but so far we're looking good.
More updates, photos, and videos to follow.
