Oil Level Sensor
How can it cause an external leak? Your knowledge and expertise is greatly appreciated.
As a matter of fact it is a very common leak in this engine.
The level sensor does sit inside the oil pan on the passenger side of the car and it has an O-ring that is supposed to seal against the oil pan. That O-ring gets hard and brittle in time and it will cause a leak.
You can just change the O-ring,but because of the time involved to do this,I would change the whole sensor,which comes with the O-ring.
Some have only changed the O-ring and the leak came back.
Good luck!
Now that I have the 12 Torx bolts removed from the lower oil pan,
what's the secret for removing it?
I can see a tab on the drivers side just below a tab on the upper pan, but I don't want to pry too hard.
Get silicone from the dealer,it's the best!
