headlight replacment
Have you tried paying for a head light restoration? This can be done professionally at most detailing shops, typically $80-$150 for a high quality service.
To be clear (no pun intended), I am not referring to the cheapie "wipe on/wipe off" headlight restoration kits.... I do NOT recommend this. And I DO NOT recommend the $25 Autozone/Oreilly kits... they are garbage in my opinion.
The true technique uses 3 to 5 different sandpaper grades, and at least 2 polishing steps.
I had my shop do this on my car, and the finish is 85% better and has lasted over a year already.
Mine are shiny and clear.
Try this first before you replace your expensive headlight.
Tap off paint area with painter tape.
Wet sand with 1500 grits sand paper, 1200 if your plastic lenses are really bad (bad as in you can't see the bulb inside) Use 1000 grit to remove deep scratches and pitted lense.
You can see it starting to desolving the oxidization layer in a milky cloudy substance.
Keep the sandpaper wet at all time no perticular motions it all get buff out later on.
Than finish up with 2000 to 2500 girts to remove all the light scratches.
Than apply headlight poslishing compound..ie Mothers, 3M, Meguiars..what ever, they all the same to me.
Than polish the lense with a high speed buffer, keep the buffer moving or you melt the plastic.
Once the hazel clear up and you are happy with the way it is than apply a coat of wax over the lenses. Good as new.
This process will restore pitted, oxidation and deep scratches on all plastic lenses. You can't really mess this up, it's idiot proof. Once you do your headlights you can't stop wanting to doing other people headlight and taillight. LOL.
Definitely try this before buying new headlamps
