Advice on spare wheel limitations
Could someone advise of any speed limitations when using the spare wheel on the rear of the car, please.
I picked up a nail and had to change the wheel. I seem to recall that there's some speed limit (maybe) as the spare wheel is the same size as the front and not the back, on the staggered wheel cars.
Unfortunately, at the same time, debris in the road ripped off the plastic under tray behind the front spoiler, so if anyone knows the part number for it, that would be awesome.
Bit of an unlucky night
If you have the steel rim, then definitely don't drive on it for long. For short term use it will be fine. Where I live I see people tearassing around the highway with a donut spare - it's amazing the stupidity...
The spare wheel is an original alloy, same size as the front one.
I've now found out that it can be used on the rear, but only as an emergency with speed limited to 80 km/hr.
Luckily, the tyre can be repaired, which is a relief.
