need source for emblem
Old Dec 24, 2014 | 09:30 PM
Das AMG's Avatar
'13 C63 AMG Coupe, '01 W210 E55 AMG
I need another merc 3-pointed star -- the one on the engine cover of a 210 E55. I searched the web without success.
Any sources would be appreciated.
Old Dec 25, 2014 | 09:00 AM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
The badge comes with the front engine cover, so you have to but the whole thing.
However, It's quiet expensive and not worth it. Most people get the W221 (for example) trunk emblem and attach it to the cover.
https://mbworld.org/forums/c36-amg-c...ine-cover.html
https://mbworld.org/forums/c36-amg-c...ar-emblem.html
Good luck
Faiz
Old Dec 25, 2014 | 01:27 PM
Das AMG's Avatar
Good luck
Faiz
Thanks Faiz. Just what I needed. Ordered it from Ebay for $15.20
I will follow Vicious_c43 instructions --
Parts used
Star emblem PN A 211 758 00 58 ($10.74)
Drill with #20 drill bit (the back stems on the star is snug fit)
Super glue
Cigar (smoke it when your done
Read more: https://mbworld.org/forums/c36-amg-c...#ixzz3MvYNs06p
Old Jan 1, 2015 | 03:50 PM
Das AMG's Avatar
Got the mb star emblem.
I decided did not to use the paper trace method to create a template for drilling the engine cover. There is too much chance for error in this method.
Instead, I used a direct transfer method which was to put white-out liquid on the ends of the star mounting pins and then press the star onto the cover, leaving the drill points clearly marked.
Used 5/32" drill bit.
Job done!
