W210 AMG suspension change with face-lift?
Old Jan 24, 2015 | 09:19 PM
Wolfenheinzer's Avatar
2000 W210 AMG
If you read about the W210 AMG in one section it says:
E55 after 2000 supplemental information
Suspension
Front: Independent double wishbone with coil springs, gas-pressurized shock absorbers and stabilizer bar.
Rear: Independent 5-arm multilink with coil springs, gas-pressurized shock absorbers and stabilizer bar. (Separate AMG-Bilstein gas-pressurized shock absorbers and progressive-rate coil springs. Larger, solid stabilizer bars.)
The last part is specific to this section. Does that mean the suspension changed with the face-lift? I can't find any evidence to support the change. So was it the same? Or did it change?
