Exhaust for dummies
SL 63 AMG Exhaust
I need some help with exhaust information. I just replaced by C63 for the SL63 AMG with performance package. I have just run it in at 5000km. Whilst the exhaust note is great it is not quite like the old 6.3 liter v8.
I am exploring after market exhaust options and need some advice on how to make the exhaust stronger without too many mods to factory kit. I am still under new car warranty and don't want hassles with the dealer.
Thanks for your help.
Best of luck!
https://mbworld.org/forums/sl55-amg-...5-amg-r230-49/
2002 E55 AMG
This probably is among the most discussed subjects in this forum.
There are three restricted zones in the exhaust:
-manifolds
-primary cats
-secondary cats.
You can install mid tube headers from Kleemann.
Shorties from (topspeed)eBay or RENNtech. If you go with Kleemann you'll have to delete the primaries.
The primary cats are monitored by O2 sensors, so deleting the cats will result in a CEL. You can either relocate the sensors to the secondary or get a tune.
The secondary cats are sensor-less, so it will not trigger any sort of message.
Most people here remove the resonator. and install a crossover (mostly an x-pipe).
Another group- Including me- chose to also delete the secondary cats.
I recommend you delete the resonator and replace the 2nd cats with an x-pipe.
It's the best mod for the $ and you'll gain a few horses across the entire rpm.
Here's my feedback.
https://mbworld.org/forums/w210-amg/...te-x-pipe.html
Resonator delete will increase the loudness and slight amount of bass (classy way of course!).
Deleting the 2nd cats will also increase the loudness a bit, but will clear the sound, make it more precise and defined.
As for the type of crossover, an x-pipe will give you more gains mid-high rpm, and will sound exotic.
an H-pipe gains will be in the lower range, and the sound will be more raspy and American muscle-like.
IMHO X-pipe suits the car better.
Also if you're going to install a crossover, install it as close to the engine as you can to get more scavenging effect.
Good luck,
Faiz
-manifolds
-primary cats
-secondary cats.
Here's my feedback.
Good luck,
Faiz
II have a 02 E55 AMG, and the previous owner removed the 2nd Cats, Resonators, and added a Magnaflow muffler. When I recently added an X-Pipe, I noticed the previous owner tried to use as much of the original pipe in his mods, and has welded pipe sections… Not a clean job in my opinion, and now doesn't have the exhaust pipe release for when I have to work on the transmission. So now I want replace the exhaust pipe with one continuous pipe.
At freeway speeds it’s a bit loud for me... Especially after a long day at 2AM… Ha! Is there a muffler that you would recommend that would sound more exotic removing that deep drone sound
Seems like most aftermarket mufflers would have more of a race sound. Have the same set up sans the Magnaflow with OEM muffler. I have a slight drone around 2000-2500 RPM but I am far from obnoxious like many of the Mustangs that are around here.
I have read that the AMG muffler is vey well designed. Best thing I can say is hit Youtube up for reference sounds.
rtuazon (10-30-2018)
2020 E 300 Coupe and 2019 GLS 400
Hey Solo,
Good luck,
LUNDY (09-29-2019)
2002 E55 AMG
Thanks Solo Wing & Tall Girrafe!
Ebay has used W210 AMG mufflers for $380.00ish plus delivery fees. My muffler guy says a Borla may be a tad bit quitter, without that deep drone. I think I'm going that route before I have to spend more with a stock muffler. I do like the louder rumble... It's just that loud drone on long, late night drives that gets to me.
PS, Cheezels, sorry if it was inappropriate to jump on your post. I rarely post and still green when using this forum. Just happen to see your post and some of the peeps here looked to know what they were talking about.
#33
The more you drive the car over time with the mods, the louder it gets. I think the new trend nowadays is the raspy sounding exhaust. I much preferred the old school muscle car sound which this W210 has compared to the newer c63s sounding exhaust.
LUNDY (09-25-2019)
#34
Registered User
Resonator removed and car is astonishingly very much the same. Even the exhaust shop said it was very similar to the original. The sound improves when you get on it. Really think I'm going to like this.
LUNDY (09-30-2019)
#36
W210 E55 AMG 1998
#39
thanks I just drove my new to me 01 e55 5hrs from Louisville. Car runs smooth. I think I will do this kids and something for handling. I was surprised I thought the car would handle better
#40
#41
W210 E55 AMG 1998
As long as you have either primary or secondary cat it will take care of that. These are old cars, removing the secondaries and replacing the primaries with 200 cell hi flow cats will do a lot of good for performance, sound and mpg.
#42
thanks that’s the plan for me eventually
#43
My primaries failed a while back. Previously I removed the resonator, secondaries and installed a magnaflow X pipe. I had an option to decat and deal with emissions or replace. I ended up going with 300 cell high flow. No CEL
#44
Have you replaced your primary cats with 200 cell? I have read that those would throw CEL or you have to use a fouler for the 02 sensors.
can you tell me where you got the primari from and part number? I might have to change mibe, I had codes that popped up. I cleared the codes drove over 100 miles so far CEL did not come back up. If it does I want to replace them.
#45
For performance I chose the Vibrant 7101. 2.5” 300 cell metallic substrate high flow cat.
The primary cat is offset meaning exhaust comes in straight and the exit pipe is at an angle back. A muffler shop will have to fabricate to fit the straight through Vibrant 7101.
There are offset options that come with ceramic 400 cell substrate if you want stock like as well as high flow options by Magnaflow. I think Magnaflow only does 200 cell on high flow however. I have those part numbers if you want.
Also Davico can fabricate a down pipe full section but is more costly.
Mine sounds great and night and day responsiveness with shorty header, high flow primary, x pipe and resonator delete.
#46
W210 E55 AMG 1998
