need source for fan shroud clip
'13 C63 AMG Coupe, '01 W210 E55 AMG
I need the clip that holds the overflow hose to the top of the fan shroud. The E55 clip is small. The mercedes parts diagram on all oem parts sites show a big clunky clip that is clearly not the oem part for the E55. Do you know of a source for our clip?
Got the clip. The factory clip is black. The mercedes part shipped to me was, you guessed it, white. I colored it black with a sharpie to match the black hose. Looks okay now. Installed it.
Anyway Pelican Parts said Mercedes is only supplying that part in white. I don't know why mercedes would be sending out white parts. Nothing under the hood is white. Go figure.
00 C200 & 00 C55 & 06 SLK55
Yeah, i'm also wondered, why white, while black is match to everything around it,,
i can assume that MB wants you to watch-out not break that clip accidentally, especially at dark/night..!!
ZAYED,,
ZAYED,,
If you do break this clip, as I did, MB's punishment is to make you install funky white parts. Is White the new black? Is Black dye more expensive, or is white more green?
