Is there something missing under the hood?
Old Feb 21, 2015 | 05:34 PM
Tall Paul's Avatar
2002 F-350, 1999 E55 AMG, AMG Orphans Club International Member #118
It looks to me that something belongs here. There's a nice bracket and some connectors, but no part. Can anyone tell me what belongs here, and if it is important? Thanks
(The big hole right behind the upper rad hose.)
Old Feb 21, 2015 | 06:39 PM
ddb's Avatar
ddb
2002 E55
I believe it is the secondary air injection pump, which is emissions related. Not sure about the importance.
Attached Thumbnails Is there something missing under the hood?-1378770722736.jpg
Old Feb 22, 2015 | 10:01 AM
Tall Paul's Avatar
Thank you. Doesn't appear to have ever been there.
Old Feb 22, 2015 | 10:08 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Seeing that you're from British Columbia, I'm assuming your E55 is a Canadian spec car. If so, the secondary air injection pump was there when the car was sold and the pump is now missing.
FWIW, my '99 E55 is a Canadian-spec car imported to the US years ago. It most certainly has the air injection pump.
The pump activates to inject additional air to reduce emissions.
Old Feb 22, 2015 | 10:19 AM
Tall Paul's Avatar
My E55 was imported from Japan. When entering into the province, it went through government mandated inspection. Apparently, it passed, or I wouldn't have it now. Probably due to the pump not required in Japan, so not installed, and our inspection states that any and all manufacturer's equipment be present if it was on the car originally. (Plus the bonus that the AirCare program has been cancelled.)
Old Feb 23, 2015 | 12:38 AM
cudaized's Avatar
2002 E55 AMG Obsidian Black with Charcoal
Attached Thumbnails Is there something missing under the hood?-02-new-spark-plugs.jpg
Old Feb 23, 2015 | 10:00 AM
IanB's Avatar
'99 E55t AMG
My Japanese import doesn't have the 2ndary air pump either, not required.
Old Feb 23, 2015 | 09:45 PM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
I wonder what difference does it make? Other then reducing emissions.
Old Feb 23, 2015 | 10:59 PM
benzokirk's Avatar
Veteran: Air Force
2008 E63 AMG, 2018 VW Golf R
I could be wrong, but I'd say probably no difference whatsoever.
Old Mar 6, 2015 | 08:01 AM
thebenzgod's Avatar
190E (blown engine), 1992 300E (t-boned), 2000 C280 (rearended), W210 E55 AMG
Awesome, I've replaced a few secondary air pumps on the M113 engine. If mine ever goes I may not replace it and check to see if I have to code the control module to Japan or not. I'm curious to know what the difference in engine running is.
Old Mar 6, 2015 | 11:55 AM
Tall Paul's Avatar
I'm guessing, but it probably has very little to do with performance. If it was belt driven, then yes. If it is for emissions control, and the pump fails, the ECM would probably go into some sort of default and adjust fuel/air mixture. Like I said, I'm guessing and going on info from the last century when I worked on these things.
