2000 e55 miss
Old Mar 3, 2015 | 11:49 AM
jjcarr's Avatar
94 e320 wagon, 95 c36, 90 560sec, 04 Allroad
2000 e55 miss
Have a curious issue with my 2000 e55. It's not throwing any codes, but I can feel it "missing" on accelleration, mainly in the midrange. It feels like off the line it's fine, and once the engine gets above 3-4k it doesn't miss as much. But, power definitely seems low. I've replaced the fuel and air filters, checked the plugs and MAF and all looks good, and there is no sign of rattling from the cats. I assumed if it had a miss I'd get a CEL code, but nothing. Any ideas? It's a 2000 e55 with 73k miles.
Old Mar 3, 2015 | 12:08 PM
cm60k's Avatar
Try to disconnect the battery about 1 hour, and see if it doing this mess or not..!?!
ZAYED,,
Old Mar 3, 2015 | 05:59 PM
desired_speeds's Avatar
2007 SL55 AMG
plug into star diagnostics. check for smooth engine running to find out which cylinder is firing out of range.
Old Mar 3, 2015 | 07:51 PM
illest's Avatar
w210 AMG or S213
cps?
Old Mar 4, 2015 | 09:14 AM
jjcarr's Avatar
I would assume a bad CPS would cause the engine to die completely rather than just have a miss, am I incorrect?
Old Mar 4, 2015 | 09:22 AM
illest's Avatar
w210 AMG or S213
it can cause rough idle as well as the typical dying.
Old Mar 4, 2015 | 10:15 AM
cm60k's Avatar
^+1^,
also less performance during high RPM..!
ZAYED,,
Old Mar 4, 2015 | 11:42 AM
jjcarr's Avatar
Given the low cost and ease, seems a good time to do the crank PS and cam PS.
Old Mar 4, 2015 | 11:57 AM
cm60k's Avatar
Replacing "crank" sensor is little hard, but "cam" sensor is sooooooo easy..
ZAYED,,
