Wheel Guru Help
Old Oct 3, 2015 | 05:42 PM
Herb5998's Avatar
2008 C350
Wheel Guru Help
All, I'm stuck in a bit of a situation regarding some new wheels and tires I picked up for my 2001 E55.
Wheels: Carlsson 2/6 18x8.5 ET35 18x10 ET30
Tires: Michelin PSS 235/40/18 265/35/18
FRONT: So doing some calculations based on offset, I had to pick up some 10mm H&R spacers for the front to clear the suspension. Also picked up appropriate length bolts to ensure a proper fit. All running smooth, no rubbing, no issues.
REAR: Based on the offset, the wheel is 17mm outward from stock, which is fine. Wheel bolts up fine, no issues. When I start driving, it sounds that something is running (or that I have tank tracks in the rear). Up on inspection, I cannot see or feel any rubbing, at all. I have double checked everything, and cannot still sort it out. Any ideas/assistance would be greatly appreciated. I know this wheelset has been used in the past by other W210 oweners, so it should work, just stuck at this point
Thanks in Advance!
Old Oct 3, 2015 | 08:49 PM
illest's Avatar
w210 AMG or S213
are you using stock length bolts on the rear?
Old Oct 3, 2015 | 09:37 PM
Herb5998's Avatar
2008 C350
Stock length bolts, but with conical head, do you think iy is that are bolts too long?
Old Oct 3, 2015 | 11:03 PM
illest's Avatar
w210 AMG or S213
If they are too long the can interfere with the emergency brake, compare one of them to the stock bolt.
Old Oct 7, 2015 | 10:20 PM
Herb5998's Avatar
2008 C350
Shorter bolts has solved the issue. Thanks for your help!
