Do i need to reset gearbox after change?
Subscribe
May 27, 2016 | 06:40 PM
hi guys just a quick question, Do i need to recalibrate/reset my auto box after i change the gearbox? car was fine before change but for some reason after a put another secondhand gearbox in the car seems to drive upto like 3000-4000rpm then pulls back like its got a limiter on or summat..
Reply 0
May 27, 2016 | 09:26 PM
I can't help you with your question but I'm sure glad you found a gearbox.
Cheers.
Reply 0
May 28, 2016 | 03:56 AM
glad!!! im over the moon mate its been quite a journey trying to find a gearbox for it, its becoming impossible now id say no one has got one, i got a quotation on recondition and that came to almost 1800GBP i couldnt afford that but luckily i found this secondhand box for 375GBP and 150GBP for garage labour.. so i hope this box takes me far
Reply 0
May 28, 2016 | 04:24 AM
Prefer to perform/adapt the gearbox manually, then reset all the system via SDS, to make sure, all RPM shift points saved correctly to the ECU/TCU data/file..!
see PDF's,,
MB 722.6 Shift Adpatation Procedure.pdf
lib_download.jsp_file=mb_7226_adaption.pdf
ZAYED,,
Reply 0
thanx mate ill try them
Reply 0
Jun 5, 2016 | 01:13 PM
Hey, quick question, does our e55 has different gear box that regular w210? I thought they are same? no?
Reply 0
Jun 5, 2016 | 07:01 PM
Yeah, all (722.6) looks identical, but the differ in the "Tq/Nm" out-put, for differ (HP) power range..
ZAYED,,
Reply 0
Jun 5, 2016 | 07:22 PM
Quote: Yeah, all (722.6) looks identical, but the differ in the "Tq/Nm" out-put, for differ (HP) power range..
ZAYED,,
so e55 has more durable gears?
Reply 0
Explore
Jun 5, 2016 | 07:35 PM
All (722.6) 1998-2006 "8" Cly.'s have stronger clutches (B1/K1/K2) than "4/6" Cyl.'s, to compatible with out-put HP..!
ZAYED,,
Reply 0
Jun 5, 2016 | 08:37 PM
so would other gearboxes from a different engine fit onto the E55? ive actually dropped my merc off to a Mercedes specialist to have the gearbox reset only because of my problem, i put my foot down yesterday and it backed off the power again but this time the ESP light came on and i think it went into limp mode.. i hope the reset works.. im also thinking have i put a gearbox from a different engine into the car cause of the issues im having
Reply 0
Jun 5, 2016 | 10:09 PM
Maybe you don't have to change your gearbox,
may have a "bad conductor plate or oil goes to your TCU or oil level NOT correct",,
have to check these first, before spending $$$$$$..!
ZAYED,,
Reply 0
Jun 6, 2016 | 05:06 AM
Quote: glad!!! im over the moon mate its been quite a journey trying to find a gearbox for it, its becoming impossible now id say no one has got one, i got a quotation on recondition and that came to almost 1800GBP i couldnt afford that but luckily i found this secondhand box for 375GBP and 150GBP for garage labour.. so i hope this box takes me far
what was the #-number on 2nd hand box you bought?
proper box for E55 AMG is 722.636, if you bought a box for a different model say a lesser E280/E320 you will break that box with the torque from your monster engine.
box from E55 - S55 - ML55 will work on your car
Reply 0
Jun 6, 2016 | 06:36 AM
right thanx mate im gona check that
Reply 0
Jun 6, 2016 | 09:22 AM
Dennis,
Ml55 gearbox is little bit weaker & housing is differ as well..!
----[Ml55>>(400N/m) VS E55>>(580N/m)]----
ZAYED,,
Reply 0
Jun 6, 2016 | 09:35 AM
ZAYED,,
hey bro
ML55 had 347HP like CLK55 engine
ML55 engine can't have less torque 510NM versus C43AMG 410NM engine, this means ML55 can't have a weaker tranny than C43AMG.
w210 E55 have 530nm
CLK55/ML55 had slightly less HP/NM than E55AMG engine, this was for marketing reasons, E55 was more luxurious than the cheaper siblings.
S55AMG had 360HP and a bit more NM than E55AMG which was a lesser model than S55AMG.
the baddest a$$ was the S65AMG with 1000NM, this monster car is a different story
Reply 0
Jun 6, 2016 | 10:34 AM
Sure Dennis,
but nothing to do with Engine torque, that's a differ thing, comparing to the transform out-put power to drivetrain,
Ml55 got "2" differential with (3.46:1) Ratio, with two-speed dual range for transfer case with reduction gearing>> 4-ETS simulated three differential locks,,
which means; the way of power is differ than all Saloon's family..
ZAYED,,
Reply 0
Jun 6, 2016 | 07:49 PM
got me car back from Merc specialist regarding the gearbox issue and it came back with nothing wrong with the box that i bought from them, they recon its the throttle body which i thought was strange as it never had that problem when the old box was in the car so im not too happy back to square one!!!
Reply 0
Subscribe
Currently Active Users (1)
