ESP lights comes on Loss of power
Old Jun 11, 2016 | 10:03 PM
Frank N Sense's Avatar
E55AMG 2000 E55 AMG 1921 Ford T Speedster
Well there you go.LOL.
Anything else you want to ad anything before I start calling. I know this one big place Dealership that I have a very good rapport with and know this one Mechanic well.
Now I want to get into some drinking so **** off and I will too.
Just joking about the **** off part.
Luck.
Old Jun 11, 2016 | 10:05 PM
allyg650's Avatar
mercedes w210 e55 amg
lol thats a rap. i love you too
Old Jun 11, 2016 | 11:35 PM
illest's Avatar
w210 AMG or S213
I used to have something similar happen if I floored the car it would go into limp mode until I restarted it. Changing the throttle position sensor fixed it. I never got any esp light that i remember. I got the part from a junk yard for a few dollars, its the same part on lots of mercs.
Old Jun 12, 2016 | 05:29 AM
allyg650's Avatar
thanx mate ill try that
Old Jun 17, 2016 | 07:44 PM
allyg650's Avatar
hi guys its me AGAIN lol
right im still trying to figure out my ESP issue on the gearbox etc i checked the gearbox that i was supplied by the independent Mercedes specialist breakers and i find out my original gearbox part number was 722636 and the box they supplied is 722623.. would that cause the problem? i found out that the box they supplied belongs to a e430 V8 not an e55 amg.. its a straight fit but i think my car will struggle to work with the electronics on the new box.. what you guys think?
Old Jun 18, 2016 | 04:26 AM
KJI3jflarryfe93's Avatar
new gearbox is not the correct tranny for your car, it won't hold tourqe from engine
it's for a lesser model maybe e430 like you said.
go back to shop and file a complaint getting the wrong box
if they don't replace your tranny coz they put the wrong box tell them you will report them to consumers bureau, you have consumer rights and warranty if you bought it from a shop!
Old Jun 18, 2016 | 05:07 AM
  #32
cm60k's Avatar
Dennis,
"W208 Clk430/W210 E430" sharing the same out-put power with all N/A (M119's/M113's), which is "A580Nm",
i put E430 gearbox on "1997 W210 E60" & "2000 R129 SL500", 4 years ago,,
no any issues with both cars till now..!
ZAYED,,
Old Jun 18, 2016 | 06:12 AM
  #33
allyg650's Avatar
Zayed do i need to change the gearbox ECU too as the part numbers not the same on gearbox
Old Jun 18, 2016 | 06:41 AM
  #34
cm60k's Avatar
No need to change the gearbox TCU, you have to use your Exist one, to match with our Vin. & diff. Ratio,
maybe something wrong with speed sensor in "conductor plate"..!,,
i prefer to diagnose the car via "STAR/SDS", to make sure what Exactly happened to the Electrical side of the gearbox..!!
ZAYED,,
Old Jun 18, 2016 | 06:42 AM
  #35
allyg650's Avatar
ok thanx bro
Old Jun 21, 2016 | 06:44 AM
  #36
kaype's Avatar
W109 300SEL6.3, W123 280TE, W123 200T, W210 E55
The CAN Errors can surely be ignored ... regarding your pictures you have Communicationerror with UBF and PSE
UBF means "Unteres Bedienfeld" ... translated in english it would bei "lower control panel" and this means the buttons around the shifter (not the shifter!)
PSE means "Pneumatische Steuereinheit" ... translated it is pneumatic control unit ... it is the controlunit for the Alarmsystem and the doorlocks.
Probably both where disconnected a while ago?
As Zayed says, check with StarDiagnoses and ERASE all error, do a testdrive and read again, then post the NEW errors.
Regarding to your picture i only see
"Safety Fuel Shut off" and "Faul in DAS to Engine Control Module" as possible source of your power loss ... first should be the Tank pressure sensor, the 2nd one i never saw before, i am sure reading errors with StarDiagnoses would give a more explicit discription.
greetings, Fabian
Old Jun 21, 2016 | 07:11 AM
  #37
cm60k's Avatar
Great Explanation Fabian..,,
"professional" as always of course..
,,ZAYED,,
Old Jul 2, 2016 | 05:13 PM
  #38
allyg650's Avatar
guys IVE FIXED THE ISSUE!!!!!!!!
you wana know what is was???
Old Jul 2, 2016 | 05:43 PM
  #39
cm60k's Avatar
Great, what was that..??
,,ZAYED,,
Old Jul 2, 2016 | 05:44 PM
  #40
allyg650's Avatar
well ill tell you, my gearbox was faulty so i replaced it with a e430 box which was a straight fit no issues there but the main problem was the gearbox dipstick pipe it was very close to the throttle lever and wouldnt let it open up as the lever was hitting the pipe.. i pushed the pipe to give the throttle lever space to move and there it was the fault solved, took it to 2 different merc specialist and couldnt solve the issue they said ESP unit and throttle valve actuator which lead me to this.. im so chuffed, for the first time i felt the full power of the V8 and felt.... simply AMAZING hehe...
Old Jul 2, 2016 | 08:52 PM
  #41
cm60k's Avatar
Waaaaa, you got that, sooooooo Awesome,,
now tell me; who's the one we can called "MB specialist", YOU or THEM..?!?!?!?
ZAYED,,
Old Jul 2, 2016 | 08:57 PM
  #42
allyg650's Avatar
hehe im chuffed.. i want to thank your guys for the help you offered me it was a very complicated subject but you helped me stay calm and offered me comfort.. thats priceless
Old Jul 3, 2016 | 08:04 AM
  #43
kaype's Avatar
Great! Happy to hear you solved it ... but:
I really dont get it...
What throttle lever? The E55 has a electronical throttle body?
greetings, fabian
Old Jul 3, 2016 | 08:25 AM
  #44
allyg650's Avatar
hi mate, thats what i thought but mine has a plastic lever "thing" connected to the throttle body so when my throttle flap opens the plastic lever thing turns with it
Old Jul 3, 2016 | 08:51 AM
  #45
cm60k's Avatar
I think you have an early version of "ME2.0" Throttle, that comes with side spring (holds with retaining plastic flap)..!
,,ZAYED,,
Old Jul 3, 2016 | 09:12 AM
  #46
allyg650's Avatar
yep thats the one
Old Jul 3, 2016 | 04:56 PM
  #47
kaype's Avatar
ah ok ... never saw this one before i think you have a pre-facelift E55?
Old Jul 3, 2016 | 05:10 PM
  #48
allyg650's Avatar
thats correct its a 1998
Old Jul 3, 2016 | 05:11 PM
  #49
allyg650's Avatar
would it be safe to remap the car? or whats the best way to increase power?
Old Jul 3, 2016 | 05:12 PM
  #50
allyg650's Avatar
the car is quick but i think the power is getting to my head lol im enjoying it sooo much waited a LONG time for this..
